Clunk when putting car in Reverse
Hey guys,
it's the first time I've experienced this, but I parked the car in a parking lot for the day and picked up my A-Spec later on this evening. The car sat for about 13 hours, where it reached a low of -12 Celcius outside, which is somewhere in the 5-10 degree Fahrenheit range. Anyways after cleaning off the windows, I started her up, she took a few more turns then normal, but started on the first shot, I didn't have to turn the key a second time. Anyways everything was fine, I waited about 25 seconds, to get her going, and then gently placed it in reverse, and at this time felt a harsh clunk. So I continued back in reverse, put her in Drive and continued driving. the car felt fine after that, I drove it sooooo slowly, until she cooled off about 10-15 min later. I didn't pass 2200 RPM with it, and was very easy on the brakes.
Now I would assume the clunk was from the tranny being soooo cold. Is this a normal feeling in the car when it's exceptionally cold? The car felt completely normal after that, just everything reacted a lot slower since it was soo cold.
Normal or abnormal?
Normal or abnormal?
Re: Clunk when putting car in Reverse
Originally posted by sc354
Hey guys,
it's the first time I've experienced this, but I parked the car in a parking lot for the day and picked up my A-Spec later on this evening. The car sat for about 13 hours, where it reached a low of -12 Celcius outside, which is somewhere in the 5-10 degree Fahrenheit range. Anyways after cleaning off the windows, I started her up, she took a few more turns then normal, but started on the first shot, I didn't have to turn the key a second time. Anyways everything was fine, I waited about 25 seconds, to get her going, and then gently placed it in reverse, and at this time felt a harsh clunk. So I continued back in reverse, put her in Drive and continued driving. the car felt fine after that, I drove it sooooo slowly, until she warmed up about 10-15 min later. I didn't pass 2200 RPM with it, and was very easy on the brakes.
Normal or abnormal?
Hey guys,
Normal or abnormal?
Happens on my TL as well ... not always when it is cold.. also when I park it on an incline. Happened in my 99 Accord... but then again... it ended up needing a new tranny. Not to scare you but take it for its worth. I think its common on Honda's.
The axeman Cometh
giovanni is right. The best thing to do when you park your car is:
put the car in neutral
engage the E brake
put the car in park.
That way you are not relying on the tranny to lock the car in place. I have noticed that practice making a big difference in how the car sounds when I first put the car in gear.
Axe
engage the E brake
Axe
TL-S driver
That's funny you posted it because it happened to me this morning. I know I felt a few times before but today I was actually going to post to ask if anyone knew what it was. My 4-runner did this when I was parked on an incline. I'm pretty sure it is normal and only happens on inclines.
On the way!
engage the E brake
Axe
engage the E brake
Axe
I'd avoid using the e-brake when parking in freezing temps. You might find that you can't drive anywhere!
Originally posted by fla-tls
I wouldn't advise someone living in a very cold climate to park using the e-brake. I've heard of incidents where the brake shoes stick to the drum because water got up in there and iced up (yes - our e-brakes are drums).
Originally posted by kennelm
Exactly. I had a friend who always used the hand brake, and one day he couldn't get his car out of the driveway until the brakes thawed out.
On the way!
how do you have the brakes thaw? I would think that the only way to heat up the brakes would be to use them, but if they're stuck...then what?
Otherwise, wait until they heat up by rising temps/sunlight. Just don't try anything that could damage them (like hit them with a hammer, etc). I guess you could try releasing the brake and tapping the drum with a hammer - but no big hits...
Hey guys,
Normal or abnormal?
Hey guys,
Normal or abnormal?
Boomer SOONER
once again, that noise you hear when you put it in reverse, or back into drive is NORMAL!!!! at least for our car, cant say it is normal in my eyes but its not supposed to be a problem...dont worry so much
engage the E brake
Axe
engage the E brake
Axe
Soul_Deamon
11-13-2018 04:44 PM
Mike Bertram
09-10-2015 09:27 AM
