Climate control sensor!!
Old Apr 21, 2006 | 04:31 PM
darshan_patel's Avatar
Question Climate control sensor!!
hey guys..this is my first theard ever...in this forum!! hope i am postin it in the right forum!!
I was just going thru the manual (btw i have an 03 TL-P SSM) and it says that ther is a climate control sensor at the bottom of the windshield. (where the defroster air vents are located in the front)
exactly in the middle there is this sensor.....was wondering why do we have that for? does it control the temperature of the air coming out even tho we had a knob to set the temperature!??
and one more thing!....sometimes i set temperature to 75 (A/C off and AUTO)and still the cold air blows. the air doesnt blow from the foot air vents instead from the upper vents about the clock??
is the climate control sensor playin a part in iT???
thanksss....guys for the help!
Old Apr 21, 2006 | 04:42 PM
Just02's Avatar
Smile
That little black rectangular sensor is a sun sensor.
Ever notice when you're driving in a dark(er) area for a set period of time that the climate control switches air flow (and even disables the middle vents next to the clock?) and then when you drive into an area flooded with sun, the middle vents open and colder air comes out? Something like that happens...
It just helps the climate control system determine the proper setting for air flow/vents and air temperature.
Old Apr 21, 2006 | 08:37 PM
but we do set the temp knob to the desired temp!!! then wats the point??
Old Apr 22, 2006 | 01:21 PM
Just02's Avatar
When you select your desired temperature, the climate control computer then uses the temperature sensor to determine the proper air mixture needed to bring up, lower, or maintain the cabins temperature. The sun sensor supplements the temperature sensor. The sun sensor lets the computer know if the cabin is being flooded with sun, if the cabin is being flooded with sun (aka, no cloud coverage/no shade) the system adapts and will change air flow and air temperature to comfortably maintain the cabins temperature.
Make sense?
Jul 16, 2017 07:33 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
RobbDizzle
Oct 15, 2015 11:16 AM
hrothgar02
Sep 28, 2015 11:08 AM
Brandle34
Sep 23, 2015 07:20 PM
