Clear tails, one man job or should a professional do it?
I really like the 02' tails and I know some of you guys have it. Can this process be done by myself or should I let a "expert" do it? Thanks!
piece of cake
If you know how to use a screwdriver and a socket wrench, you can change your taillights. The procedure to get to the bulbs is in your owner's manual. While you're there, just remove six nuts from each light and they're off. Make sure to transfer over the wiring harnesses too. It's easy, you'll know what to do the moment you see it.
Note that the fit of the turn signal bulbs will be different. You can either get the new wiring harnesses with the 2002 taillight assembly, or just use some tape to hold your current turn signal bulbs in place better.
BlingBling INSPIRE 32V
Do it yourself. some screws...that's it!
The only thing you're gonna have to worry about is back-up lights. Because 02 TL's use bigger housing for the back-up light bulb. You just buy the harness for it or just tape it!
Peach Tea
yes, very easy, i dropped a screw and couldn't get to it but... oh well. also, i kept the same wiring harness and dropped in some Polarg M2's. they look sweet. just had to tape up 2 bulbs.
good luck!
good luck!
It's pretty simple to do! I helped my frined out a couple weeks ago and it was like a walk in the park! But it did take us half the day to clear out the front one and hoping that it won't leak!
Originally posted by TommyBoiSxty9
kan u clear the 99-01 tails so i dont have to buy new ones??
Originally posted by bebber
Nope. sorry. The whole lens is amber, so there is nothing to clear. You can spray tint them another color (red, smoke, etc) or just replace them.
lol
i miss the good old days when me and my friend cleared out the tails for his 96 accord... it was amber but it was clear outside so all you had to do was get rid of the amber lens.... of course you had to crack it from the inside, making this job take like 3 hours
SinCityTLX
55
10-11-2015 01:20 AM
