Cleaning Intake Manifold - Can't get bolt off
Flyin' and Drivin'
![Angry](https://acurazine.com/forums/images/icons/icon8.gif)
I'm trying to clean my intake manifold on my TL-S, and I've got everything disconnected, but I CANNOT get a bolt off.... it's on page 9-5 of the helms manual, it's the bolt securing the TCS control valve bracket. It's the big bolt in the center of the picture. I've sprayed it with WD40 and seafoam deep creep.
It just won't budge. If I can't get it off, I don't think I can get everything disconnected so I'll have to give up. I really need to get to the IACV too and clean that out as it's been giving me problems.
Any ideas?![Annoyed](https://acurazine.com/forums/images/smilies/annoyed.gif)
Any ideas?
![](http://img.photobucket.com/albums/v715/comet2404/photo-8.jpg)
yeedatoy (01-29-2012)
Flyin' and Drivin'
Flyin' and Drivin'
![](http://img.photobucket.com/albums/v715/comet2404/photo1-2.jpg)
![](http://img.photobucket.com/albums/v715/comet2404/photo2-3-1.jpg)
![](http://img.photobucket.com/albums/v715/comet2404/photo3-3-1.jpg)
![](http://img.photobucket.com/albums/v715/comet2404/photo4-2-1.jpg)
And yeah - you're right about the EGR ports. The whole thing is just cruddy, and it needs a good cleaning. Check out the above pics.
the bolt should round before the socket strips unless you are really using CHEAP tools. Are you getting the socket on all the way? Put some leverage into it.
I need 2 more gears
Buy an air tool hardened steel six point socket. No way on earth that will strip. It may rip the head of that bolt off if it's seized though. Be careful. Also try tightening it and then loosening it. Back and forth a few times, then spray some PB Blaster on it and let it sit. Do this a few times and then put your breaker bar on your racket (I use a big ass steel pipe) Give it a nice solid initial tug and then moderate pressure. Don't go hercules on it or you'll rip that bolt in two. You can get that bolt out of there. Be patient.
95CivicNOWa99TL (01-31-2012)
bringin lead
where in atl are you? i have a 2 foot breaker bar and some muscles you can borrow. heck, if there's a garage and some beer involved, i'd be willing to lend a hand.
Flyin' and Drivin'
I live two blocks from Turner Field. I don't have a garage though - only my private street. I do have beer though! Have you done any IM cleaning? I'd love to get those EGR ports cleaned out.
Can't believe you stripped 2 sockets. Have to be real cheapies -or the wrong size. A decent 6 point Craftsman socket and 1/4 inch drive will get that off. I have broken the heads off bolts before stripping out a socket.
Odd.
Let us know how it works out.
Odd.
as said before- try tighten slightly then loosen- that often breaks the corrosion bond thats formed
any penetrating fluid should get in there overnight and help too
all else fails- vibration via hammer and socket
DONT go superman on the bolt or it will happily snap off-
leaving you slightly more ~screwed~ that you are now~
EGR= exhaust gas recirculation sends partially unburnt fuel/exhaust back into intake manifold for reburning
Runs all the time except idle and full throttle
no way for seafoam to do anything about this particular problem
Flyin' and Drivin'
Well after a local mechanic got that bolt loose for me yesterday, I was able to tear everything down today and clean the crap out of everything. Looks great, and runs great! I wasn't able to do the seafoam today though, as it got dark. I'll do that tomorrow! I changed out my cabin air filters while I was waiting for the engine to cool, which was another thing on my list.
All in all a great day - and couldn't have done it without you guys!
Thanks!
Thanks!
please see our diy -for 03--thats the best one, and www.seafoamsales.com
fuel injected cars section and the other tech bits for best overall methods
just above idle is not all we should be doing
read and follow some 2000 rpm method
Flyin' and Drivin'
Can't wait to foam the TL tomorrow! I cleaned that crap out of that IM today. I couldn't believe how much crap came out of there. It looks brand new!!! Most of the smaller EGR ports were fairly clogged... I'd say about halfway clogged. The main one was also in rough shape as you can see in the pics above. It's all clean and shiny now though!!! I did end up taking the plenums off and cleaning those too. It made the entire process easier.
AZ Community Team
Received 7,770 Likes
OTOH, when I did my '07 I did not replace the cover gasket and it's never been an issue as far as I can tell.
cycdaniel
12-17-2019 10:58 AM
JarrettLauderdale
2G CL Dynograph Gallery
09-21-2015 07:51 PM
