christmas for the tl....
christmas is coming up and im not sure what to get the tl.
2k2, type-s, tinted, aem cai
a. front lip, who all makes front lips for our cars?
b. rear swaybar
c. apexi ws2 catback
d. hids for the fogs
e. vafcII
f. anything else?
i could do two of the cheaper items such as front lip/rsb or just a vafc, hids, catback, ect.
what do you think?
b. rear swaybar
e. vafcII
f. anything else?
what do you think?
Best lip is the oem.
wouldnt waste my mney on the bafcII unless you start to get alot of mods and plan on dyno tuning.
Id do the comptech sways, and the HiD's for teh fogs
alright seems like swaybars is in favor; how about a braking upgrade?
slotted/dimpled rotors, ebc greenstuff pads, ss lines?
i may also be able to get a good deal on a 3rd gen's brembos; guy i know got the back end of his car taken off by a semi in his work parking lot and is going to try to part the car out.
anyway to make those calipers work on a 2nd gen?
what should i expect to pay for the oem front lip?
and what size are the stock fog bulbs?
stock fog bulbs= 9006
oem front lip= i dont think they sell them piece by piece... but for a full kit you should be
expecting to pay 600-1000
sway bars= neuspeed, eibach, comptech and like Technique suspensions or something
not sure on the Calipers though.
99 SSM Tl
Originally Posted by chris1188
is comptech the only company who makes sways for our cars?
and if you could answer the above
thanks
thanks
ChairmanMaoSaysRTFM
how hard is it to install the front swaybar?
i know rear will be cake but am concered about the front
thanks
thanks
stay away from comptech. the bars they use are hollow and i had my front swaybar (comptech) snap in two earlier this year because it rusted from the inside out due to trapped moisture.
SSTS
Purchased: April 28, 2001
b. rear swaybar
e. vafcII
f. anything else?
what do you think?
b. rear swaybar
e. vafcII
f. anything else?
what do you think?
Looking at your mods list...I think lowering it should be #1.....if not then sways. I'd vote for HID fogs next....but the problem is you drive in snow...and the reason is that I'm not 100% sure if the HID kit you'll get for fogs will get hot enough to melt the snow build up.
If it doesn't...then that mod is a complete waste and you might just end up shorting it instead. Also...I'd probably not put on HID fogs without some sort of protection like Lexan lens...or at the very least a clear bra over the glass.
As for the front lip....I wouldnt get that unless you get the whole kit. I definitely wouldnt get the vafcII...and I'd think twice about getting the catback.
For functionality the sways are your best best...but I'd lower it first so you can at least get a better look. I got sway first and after going through the experience myself, I'll always lower first before adding sways.
Besides...having a higher ride with stiffer sways will only increase your chance of broken endlink rods and brackets.
99 SSM Tl
Originally Posted by NYZGREATST
i thought sways make handeling difficult in the snow?!
Originally Posted by BIG_KOUT
I would go HID for fogs first
then exhaust
then vafc
then front lip
then rear sway bar
then exhaust
then vafc
then front lip
then rear sway bar
Id pick up a UR pully LONG before i even thought about a vafc
still on stock rubber; this spring i plan on picking up a set of 19 ronjohn inspyres or what ever they are.
I have experence with a vafcII and have use of an aem wideband af gauge till i sell my rx7 to use to tune.
i want to wait on suspension till spring with rims/tires so im guessing the wsII or hid fogs for now.
does the tl with the wsII resemble a g35 coupes exhuast tone?
not sure on that exhaust but the comptech does resemble it
