Checking Tranny Fluid
Old May 23, 2006 | 06:24 PM
Black TL's Avatar
Hi,
When I start my car and throw it into reverse, it's no longer a smooth transition. In fact, it's very very hard (as if I did a neutral drop). I checked my tranny fluid and it was very low (below the first dot). My friend says that - unlike checking your oil - you're supposed to check your tranny fluid with the car running. Is this true or should I add some fluid to it?
Roshan
Old May 23, 2006 | 07:01 PM
SodaLuvr's Avatar
In Hondas, the automatic transmission fluid level must be checked with the engine OFF immediately after driving for 10-15 miles, or until the fluid is at normal operating temperature.
Old May 24, 2006 | 08:13 AM
fla-tls's Avatar
On the way!
My first tranny had a harsh reverse engagement that started about a month or so before it went down for the count.
Old May 24, 2006 | 10:23 AM
Mr Hyde's Avatar
Check it with the tranny, and engine hot just after a good drive, as soon as you turn the engine off. Unlike with engine oil where you'd check it cold, or after giving it awhile to allow all the oil to drain back into the pan.
Yikes
May 3, 2021 04:29 PM
fifer16
1G RL (1996-2004)
Oct 16, 2015 08:54 AM
Marmbo
4G TL Problems & Fixes
Sep 21, 2015 09:39 AM
ghuns
Sep 16, 2015 04:26 PM
HeloDown
Sep 8, 2015 06:51 PM
