Check engine light code: 134765
Hello,
My check engine light came on.
I got the code read and it says:
Code:134765
PO - 740
Torque converter
Clutch solenoide
Anyone ever have this?
Any suggestions on moving forward with fixing it?
Thank you.
Code:134765
PO - 740
Torque converter
Clutch solenoide
Thank you.
The 740 is a trans code. That code typically means that your trans is on its way out. You can try changing fluid and cleaning/replacing all the solenoids but usually all that does is buy you a small amount of time if you are lucky.
HeloDown
09-08-2015 06:51 PM
