Check engine light.........
Old 05-25-2003 | 06:34 AM
asiankidd's Avatar
help my CEL just when on and i need to know wats causing it, i was looking up info on where is the port that we need to short to get the light flashing but no one talks about it, can someone direct me to the port that needs to be short(not under the coin tray but another port) thanks
btw if you have the read out does anyone have the look up chart for each flash mean too? like if i get a code 22 wat does that mean? or if someone can check is the one i have here works for a tl-s?
Trouble Code
0 Faulty ECM
1 Left HO2 Sensor
2 Right HO2 Sensor
3 Manifold Absolute Pressure (MAP)
4 Crankshaft Position Sensor (CKP)
5 Same as 3
6 Coolant Temp
7 Throttle Position Sensor (TPS)
9 No. 1 Cylinder Position (CYP)
10 Intake Air Temperature (IAT) Sensor
12 Exhaust Gas Recirculation (EGR)
13 Barometric Pressure
14 Idle Air Control (IAC) valve
15 Ignition output signal
16 Fuel injector
17 Vehicle Speed sensor (VSS)
18 Ignition timing adjuster
23 Left knock sensor
35 Traction control system
36 Same as 35
41 Left Oxygen sensor heater
42 Right Oxygen sensor heater
43 Left fuel supply system
44 Right fuel supply system
45 Left fuel metering
46 Right fuel metering
53 Right knock sensor
54 Crankshaft position 2 (CKP sensor)
59 Cylinder position 2 (CYL or CYP sensor)
thanks
jon
Old 05-25-2003 | 10:21 AM
Tom Blasing's Avatar
is the Mighty Favog
I would love to get a code reader that reads Enhanced Codes not just the basic ones. Ya know, the ones that might tell you exactly what fuel injector in low on pressure not just the whole system.
Old 05-25-2003 | 10:48 AM
yield2s's Avatar
jon you just put headers on right? did you clean them out first? did you put the ox sensor on wrong? when did the light first come on in relation to the header install? was it a few hundred miles later or right away?
Old 05-25-2003 | 12:50 PM
asiankidd's Avatar
few miles later
Old 05-25-2003 | 01:44 PM
yield2s's Avatar
DID YOU CLEAN THEM OUT???????(HEADERS)
Old 05-25-2003 | 01:46 PM
asiankidd's Avatar
yes i did thats why im kinda hesitant, does anyone know how to get the cel to flash so i can look it up?
Old 05-25-2003 | 02:00 PM
yield2s's Avatar
JON,
AFTER READING YOUR POST AGAIN I'M CERTAIN YOU SCREWED UP YOUR OX SENSOR. EITHER THE ONE IN THE HEADER OR THE ONE IN THE CAT. EITHER WAY IT'S PROB CAUSED FROM THE HEADER INSTALL, I REMEMBER SOMEONE ASKING IF THEY NEEDED TO CLEAN THAT BLACK SOOT FROM THEIR HEADER, I REPLYED WITH A BIG YES AWILE BACK.
I'M A BIG FAN OF DOING MY OWN WORK BUT THE MOST IMPORANT PART OF BEING YOUR OWN MACHANIC IS KNOWING WHEN YOUR OVER YOUR HEAD.
I WISH YOU LUCK, DUDE
Old 05-25-2003 | 02:03 PM
asiankidd's Avatar
yeah i know wat you mean, but im sure i cleaned it out well, and i drove it for a whole lot of miles b4 it came on, it was actually weird cus that day i had the muffler shop put back on the stock resonator for the exhaust and soon after it came back on but i dont see how they could have messed up when non of the sensors are back there....any idea how to read the flash tho, cus i have been experience weird ticking noises under the hood near the master brake cylinder.....there is a relay that connects to some pipes it clicks and i never heard it b4 till now...any idea?
JON
asiankidd's Avatar
btw yield2s are you online via aim or anything i would like to talk to you about some header questions, thanks
JON
Old 05-25-2003 | 02:22 PM
yield2s's Avatar
YA JON IM AT claude2002typeS on AIM but i'm heading outa town so hit me up later.
Yikes
05-03-2021 04:29 PM
fifer16
1G RL (1996-2004)
10-16-2015 08:54 AM
Billu99tl
09-13-2015 11:30 AM
HeloDown
09-08-2015 06:51 PM
bryan zaragoza
09-08-2015 12:28 AM
Quick Reply: Check engine light.........
