Changing Signals In Front!
There are clips connecting the fender to the black plastic cover. Take a flat screw driver and remove the clips along the fender. If you can't reach under there becuase you lowered ur car, or you have huge arms, you might have to jack up your car. If you have big arms, get someone with smaller arms, it's easier. Slide ur hand inbetween the fender and the black cover in the direction of the signal bulb, feel for the wires, after getting a hold of the wires move ur hand to the bulb socket and twist and and the bulb and the socket will come out, replace the bulb and reverse the process
there is also directions in the manual, take a look at it.
