changing signal bulbs! help
Old May 9, 2002 | 11:09 PM
i need help on how to change the signal bulbs~!!!!
i read the manual but that just doesn't help at all
HELPPPPP!!!!
Old May 9, 2002 | 11:12 PM
lilboykorea's Avatar
uhhh really? cant u just figure it out?
Old May 9, 2002 | 11:26 PM
If you're talking about the fronts they're a bi+ch I've never done but i know the lay out and its not as easy as one might think.But if your talking about the rears then you should have no prob. its a very poor design just to change something as simple as a turning bulb.
Old May 9, 2002 | 11:31 PM
NsX Pilot's Avatar
ive done the fronts and alll i have to say is,,,,i hope u got long arms and arent afraid to get a little dirty and im surprised that they designed them like that .
Old May 9, 2002 | 11:35 PM
yes i mean the front, and by the way how did u get the inner fender to come off, that's the part i'm having trouble with
Old May 9, 2002 | 11:41 PM
badazzTL's Avatar
Peach Tea
I thought it was pretty hard at first but its rather simple when you think about it. All you have to do is peel back the inner fender. Don't be afraid to do it, you can put it back. If its tucked between the bumper, use a screwdriver or something to seperate it from the inner bumper. all you have to do after that is reach in there and feel around. good luck!
Old May 10, 2002 | 11:35 AM
AcuraTL's Avatar
OG
If your car is not lowered, here is how to do it. For the left turn signal, first turn your wheel all the way to the right. Then you will need to pop off the clips that hold the inner liner. Once you can pull the inner liner loose, stick your hand all the way in and you will feel where the connector is to the turn signal bulb. An easier way to do this is to remove the wheel and/or jack up your car.
pplcrew
Jan 30, 2021 08:59 AM
Silverstead1
Sep 17, 2015 06:45 AM
acuraST
Sep 17, 2015 02:31 AM
Greengecko
Sep 16, 2015 08:19 PM
Aleax
Sep 11, 2015 11:31 AM
