Changing engine/tranny mounts - any specific order to save time
Old Jan 18, 2016 | 11:53 AM
knice's Avatar
03 tls - bought all oem motor/tranny mounts. Can you offer any specific ordering/instructions which could help expedite the repair?
Also with the vac line that connects to the 2 mounts - I noticed some come prefilled with fluid and I just have the oem hose with no fluid. Do I need to buy some type of fluid to pre lube the hose prior to installation?
Old Jan 18, 2016 | 12:23 PM
Karanx7's Avatar
Unregistered Member
The fluid is sealed inside the rear mount. You can't change or add to it. Broken mounts can leak the fluid though.
Front, side, and tranny mounts are easy. The rear will prove to be annoying.
