Changing alarm's red LED to a blue LED..
Old Feb 23, 2003 | 09:26 PM
@cUr@-TL's Avatar
'99 Acura 3.2TL
Hi
i wanna change the red alarm led in the driver side door to a blue led. i found the instructions to remove the door panel, now i need to know what ill have to do to install the new LED.. im not using a LEd made only for automotive use so i guess ill have to use a resistor (just like for the vtec led project) of 330ohms..
if i do that will the led work??
thx
@cUr@-TL
Old Feb 24, 2003 | 12:45 AM
Darkshear's Avatar
l33t
Actually i already did this, its no big deal tp yank the old LED, just gotta be careful with that solder iron. I used a simple 12 volt all purpose LED, cause thats whats in there now. The little circuit board already has the resistors on it. Direct swap! Looks good too... red = yuck.
Old Feb 24, 2003 | 02:38 PM
NYzInfamous's Avatar
where do you get the blue LED?
Old Feb 24, 2003 | 05:16 PM
@cUr@-TL's Avatar
'99 Acura 3.2TL
ok so i just have to buy a regular blue LED (i dont need a blinking LED because the circuit make it blink) and it's a direct swap! that's cool
Old Feb 24, 2003 | 05:17 PM
@cUr@-TL's Avatar
'99 Acura 3.2TL
@cUr@-TL
Old Feb 24, 2003 | 05:28 PM
asiankidd's Avatar
you dont need a resistor cus the led circuit running the red led is already limiting the current so just get any blue led, i suggest a wide angle 5mm led
Old Feb 25, 2003 | 09:22 PM
@cUr@-TL's Avatar
'99 Acura 3.2TL
Thx for ur help
@cUr@-TL
Old Feb 25, 2003 | 09:24 PM
Darkshear's Avatar
l33t
Yah, 5MM wide angle. I couldent find any cheap ones at Radio Shack so a local little shop had them in bulk, about $2 a piece...
Old Feb 25, 2003 | 09:54 PM
SilverUA5's Avatar
Isn't blue a little hard to see under certain lighting conditions?
Old Feb 26, 2003 | 02:41 AM
KidD WiTh 2k TL's Avatar
i actually did that a while back and my hid i got is really really bright blue . . i mean its so bright . . . that 2 leds up my garage
i got off some GALLIUM NITRIDE led . . make sure u get those if u want them bright
mada51589
Jan 9, 2025 04:40 PM
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
Aleax
Sep 11, 2015 11:31 AM
pesobreeze
1G RL (1996-2004)
Sep 3, 2015 12:26 PM
