change calipers????
Old Apr 16, 2005 | 03:15 PM
1st timer's Avatar
UB6IB9
change calipers????
When i changed my brakes, i took a look at the rear ones and they were FINISHED(pads)
the mechanic told me that the calipers were a little seized so he put some antiseize grease on them and said they should be fine now.My question is,should i bother buying new ones?(i use the foot brake everyday.)
Old Apr 16, 2005 | 03:28 PM
mclarenf3387's Avatar
The foot brake is different than the rear brake caliper. It is actually a drum brake that holds the rear wheels when applied.
Granted most of your braking force is done by the front brakes, I would still replace the calipers if they are bad. I would get it looked at by another mechanic, sounds a little wierd that the rear calipers would sieze, but its totally possible.
Old Apr 16, 2005 | 03:31 PM
1st timer's Avatar
UB6IB9
i think it's the front ones that seized and most of the braking was done with the rear ones because of that.
Old Apr 16, 2005 | 03:46 PM
Then definitely replace the calipers. The front do like 75% of the braking and it will hurt your braking distance if they are not working properly.
Old Apr 16, 2005 | 04:05 PM
1st timer's Avatar
UB6IB9
but the mechanic cleaned them up and put antiseize grease on the moving parts,i think they should be fine!(i hope)
Oakes
Wash & Wax
Nov 12, 2015 09:34 PM
merc009
Oct 3, 2015 12:59 AM
aztec209
Sep 16, 2015 04:23 AM
Aleax
Sep 11, 2015 11:31 AM
HOWELLiNC
Sep 10, 2015 01:39 PM
