change calipers????
UB6IB9
change calipers????
When i changed my brakes, i took a look at the rear ones and they were FINISHED(pads)
the mechanic told me that the calipers were a little seized so he put some antiseize grease on them and said they should be fine now.My question is,should i bother buying new ones?(i use the foot brake everyday.)
The foot brake is different than the rear brake caliper. It is actually a drum brake that holds the rear wheels when applied.
Granted most of your braking force is done by the front brakes, I would still replace the calipers if they are bad. I would get it looked at by another mechanic, sounds a little wierd that the rear calipers would sieze, but its totally possible.
merc009
10-03-2015 12:59 AM
