CEL under hard acceleration?
Old Jul 28, 2013 | 07:34 PM
Golfe .:R's Avatar
Under WOT the CEL light flashes for about 30 seconds then goes away. Has this happened to anyone before?
Old Jul 28, 2013 | 08:22 PM
3.2TLc's Avatar
Have the codes checked. If the CEL came on, it should have a code stored.
Any other issues ?
Old Jul 28, 2013 | 08:35 PM
Karanx7's Avatar
Unregistered Member
It was a misfire code.
Old Jul 28, 2013 | 10:55 PM
Golfe .:R's Avatar
Also my SRS light is on. I guess i should just bring it to Acura.
Old Jul 29, 2013 | 08:31 AM
3.2TLc's Avatar
Have ya tried to reset the "SRS" light ?
If ya wanna save a trip to the stealership, check out the 2nd Gen's "DIY" sticky. It's the 3rd one down from the top of the page.
Within the DIY's is a very simple procedure to try....if it fails to reset or should the "SRS" light come back on again after the reset, then ya have no choice....but to seek more skilled help if ya want the problem fixed.
Old Jul 29, 2013 | 09:12 AM
Golfe .:R's Avatar
I tried the reset and we will see what happens. I did pull apart my dash and do the LED conversion for the gauges so I think that's what tripped it because it wasnt on before. As far as the engine light, should I get Acura to check it out?
Old Jul 29, 2013 | 09:19 AM
3.2TLc's Avatar
Have a local auto parts store read the "CEL" code for free. Then tell us what it is.
If the CEL only comes on during "WOT"....and seems to be otherwise running normal, it may just be a built in ~warning~ of sorts, IDK. But, anyways there should be a stored code, have it checked out.
Old Jul 29, 2013 | 12:41 PM
Karanx7's Avatar
Unregistered Member
You have a misfire under WOT conditions. Not a big deal if you aren't beating the shit out of your car everywhere.
If you want to fix it, check spark plugs and only use Premium gas. SeaFoam can clean out some crud from the years.
Old Jul 29, 2013 | 12:45 PM
karanx as always is spot on!
Old Jul 29, 2013 | 12:48 PM
Golfe .:R's Avatar
Im gonna go get some new plugs and throw those in and see what happens. I don't beat on it a lot, that's not what the car is meant for. But getting on the highway at 6000 feet with a NA V6 requires a heavy foot. The thing is a pig up here.
Thanks for the replies guys! Hopefully I can get it worked out!
Old Jul 31, 2013 | 10:11 PM
Golfe .:R's Avatar
Went to the Autoparts store today. Misfire on cylinder 1 and 5. Got some new NGK plugs as well as the BG 44K fuel system treatment and we will see how it goes!
Old Aug 1, 2013 | 08:29 AM
3.2TLc's Avatar
Yeah, BG fuel cleaner is good stuff. Try that first, run the tank down letting it clean the deposits...and then replace the plugs. Clear the codes. Should the CEL come back later, ya may wanna consider buying one coil and see if ya can isolate the misfire.
Old Aug 2, 2013 | 10:51 AM
Golfe .:R's Avatar
I can not for the life of me find the damn SRS reset. I found it before but now I can't seem too... Am I just a retard? Where's it at?
Old Aug 3, 2013 | 09:17 AM
3.2TLc's Avatar
Simply go to the top of the 2nd Gen TL forum's main page and then scroll down to about the third "sticky" post for the official 2nd Gen "DIY" thread. Once you're in there, ya will find all the good repair stuff for most of our common TL issues.
Or ya can just search for the "SRS" reset.
But, if ya already done it ....and the light is back on, ya may end up having a real problem with the SRS system.
Mike734
Dec 10, 2021 01:25 PM
mlody
Dec 4, 2019 02:11 PM
08KBP_VA
Oct 22, 2019 01:55 PM
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
