Car shaking violently >40mph while accelerating?
Old Oct 25, 2007 | 06:30 PM
AGPSuperstaR's Avatar
Wow, it's been a VERY long time since I've posted here but I recently picked up a 99 w/ Navi for a hella deal. Anyways, there is a problem with the car. Under acceleration over about 40mph+ the front end of the car would shake as if the wheels were not torqued down properly. I checked all the motor mounts and saw that the side mount was busted, so I went ahead and replaced it, hoping that it would solve the problem. After installation, I took it down the road, the problem is still there. I checked all the suspension components and everything seems fine. The wheels and tires are also fine. This shaking only happens when I'm accelerating, and when I let go the gas, the car cruises normally. I'm totally bummed out and can't figure out what's wrong. Can someone help? THANKS!!!!
Old Oct 25, 2007 | 06:48 PM
01tl4tl's Avatar
Have the cv joints- axles-hubs checked
they are normally the prob when shake on accell only
Old Oct 25, 2007 | 08:12 PM
acutee's Avatar
Sounds like CV joints.
Old Oct 27, 2007 | 11:08 AM
I'm changing out the passenger CV today, I'll keep you guys updated. Thanks!
Old Oct 29, 2007 | 10:11 PM
thescoundrel's Avatar
I had the same problem too, when I accelerate between 40-60, it felt like something clunking with my driver side wheel, almost like something loose. Anyways, I just replaced the axle hub bearing and no more clunking during acceleration. Hope this helps.
You can replace the bearing yourself but you will need to find a shop to press fit a new one, unless you got a press in your garage.
Old Oct 30, 2007 | 09:03 PM
WOOT!!!
It was the passenger side axle/cv joint. I got it replace and its back to normal. Thanks guys!
Old Oct 31, 2007 | 04:53 PM
jjashaa's Avatar
Avant Garde Wheels
i have that problem.. BUT! while braking o.O?
Old Oct 31, 2007 | 07:07 PM
JetBlackAC's Avatar
how much did the new cv cost?
Old Nov 1, 2007 | 08:25 AM
$50 plus $75 to install since I couldn't get the axle nut to pop open even with a breaker bar and a 3 foot cheater.
If your brakes are shaking while braking, your rotors are most likely warped.
Old Nov 1, 2007 | 04:46 PM
socko's Avatar
Have you checked wheel balance. Out of balance wheels will cause a shaking. Wheels should be balanced on both sides (ie. inside and outside).
Old Nov 1, 2007 | 06:18 PM
uncald4's Avatar
Former Sponsor
Mine did the same. Had to replace axle. I swear this is a known problem. Just like the motor mount issue. Replacing the axel set me back $700 at Acura of Seattle.
Old Nov 1, 2007 | 07:57 PM
JDM96specCTR's Avatar
holy shittttttttttttttttt
Old Nov 2, 2007 | 01:10 AM
Gfaze's Avatar
S E L L
Old Nov 2, 2007 | 01:36 AM
2K3_TLs's Avatar
OMGWTFVTEC
wow...
did they use lube when they raped you?
Old Nov 2, 2007 | 09:46 AM
uncald4's Avatar
Former Sponsor
Originally Posted by 2K3_TLs
wow...
Well, they gotta charge you $90 right off. Just for pulling in. Then another $200 for two hours of troubleshooting. If they replace an axle they have to balance and align the front of your ride. That's another $190. You can choose to buy the "economy" replacement axle for around $60 bucks. Or you can spring for the OEM replacement axle, like I did for $160. Add your share of state sales tax and you're at 700 clams. No lube.
Feb 25, 2020 09:57 AM
orkoTL
4G TL Problems & Fixes
107
Sep 28, 2017 09:12 AM
2012wagon
Sep 29, 2015 04:21 PM
kixo
Sep 5, 2015 08:54 PM
NSolace
Sep 3, 2015 08:14 PM
