Car shaking....
Possibly warped rotors... The stock rotors that came with the TL's are notorious for warping. Take it in if it's still under warranty otherwise I would suggest going for an aftermarket rotor.
@ slide or die @
hey, do you mean that when you breack fast you feel like the weel has a vibrator in it??
> happened to me friday when i had to stop from 142-0 because or a redlight far off. i sorta downshifted with ss to help the cause...maibe thats the reason.
the rotors. if you feel the pulsing/shaking while applying the brakes, its the rotors
Originally posted by Dark DJ
i thought the u felt pulsating w/ ABS? cuz my steering shake as well when i brake at high speeds
2400 Watts in a TL...Why?
1 Post
shaking in the wheel typically means the front rotors, if you feel the shaking but not in the steering wheel and more in the seat, that tends to be the rear rotors.
Received 2,329 Likes
Yep, warped rotors. Happens on 1st and 2nd generation TL's and RL's. Sucks
Mine are just a bit warped, slight vibration in the steering wheel when I brake at high speeds. It is definitely not the ABS.
Show me da MONEY
I am going through this dilema as we speak with warped rotors. My good friend is an acura mechanic and he mentioned to me even with replaceing the rotors under warrenty they are sure to warp again. He suggested buying Tru Stop sloted rotors they are gaurantied not to warp. He actually has them on his acura and he says the stoping power is incrediable. He gets a really good deal on them as well, so I will probably purchase them from him. He also stated that the Acura dealership he works for has actually been buying them from him for customers that have had there rotors replaced a few times. By the way if you do go with the rotor replacement under warenty insist that they replace them and not just turn them....
