Car was running hot w/ me but not dealership
Young Fresh 2 Def
OK, so my car has been at the dealership for about 2 weeks now for two reasons:
1) the a/c was not blowing cold air
2) the thernostate needle got real close to the H.
Just called the dealership and said they have fixed the a/c problem (turned out it was a wire that was not connected) but they said the car did not over heat once with them. The service guy said they had the car running in the sun for 2 hours and nothing happened.
What do you guys think about that? Cus I'm at a loss for an explanation here
BTW They gave me a 2004 TL as a loaner, its a great car but I like my TL-Type-S just a little bit better.
I need 2 more gears
if it's running hot could be a bunch of shitty things happening. Thermostat is the obvious answer, but could be a radiator leak, low coolant lever, wiring problem with ECU not reading the thermostat sensor correctly or at all. Get a code check done and see if it pulls any codes. Your CEL doesn't have to be on for their to be a sensor problem. The sensor could be working, but poorly. I my case my primary 02 sensor isn't the greatest and my CEL was on then went off about 8k miles ago and hasn't come back on. I know it needs to be replaced, but will wait a few more weeks until I get my bonus to fix it. A coolant flush wouldn't hurt either.
