Car Pulling to the Left
Old Apr 10, 2012 | 08:53 AM
Karanx7's Avatar
Unregistered Member
Hey guys, I have been having an issue where the car pulls to the left if I let go of the steering wheel. It is slight, but it always pulls to the left.
I don't believe the alignment is the problem. I had my wheels aligned at Firestone, and it didn't fix it. Then I had the rear subframe and front cross beam replaced, and the dealership did the alignment for that.
Still, the car pulls a bit to the left. The Firestone noticed the left tires were deflated compared to the right, so they reinflated all sides to spec. Still, problem persists.
What can cause this? Bad tie rod?
Old Apr 10, 2012 | 10:05 AM
01tl4tl's Avatar
so firestone set the align THEN ckd tire pressure??
thats enough to throw it off balance
ALWAYS set tires first!!
guessing your car took a severe hit in the past? frame ckd for straight?
Old Apr 10, 2012 | 10:38 AM
zmwang's Avatar
uneven tire?
Old Apr 10, 2012 | 02:22 PM
Skirmich's Avatar
Have the same Problem But to the Right hahahaha
Im living with it for now... But Still Piss me Off...
Did the Same fixes as You did (Except for Rear Subframe) = SAME.
Old Apr 10, 2012 | 04:31 PM
TLer trash's Avatar
Starting with the front, swap the tires side to side. If the pull changes or goes away it's a tire problem. If there is no change, try the rears. Unless you have adjustable control arms or ball joints, the only alignment angle that can be adjusted is toe, which shouldn't cause a pull. It's ok to do this for test purposes even if you have directional tires.
Old Apr 10, 2012 | 04:48 PM
fsttyms1's Avatar
Caster angle can cause this too. Do you have your alignment spec sheet to see what they are set at?
Old Apr 10, 2012 | 09:50 PM
Msouza91's Avatar
Mine does the same except town fair tire told me my rear toe adjustables were frozen
1lowtc
1G RDX (2007-2012)
15
Nov 19, 2015 10:52 AM
Phambam12
Sep 6, 2015 06:57 PM
jordanboi
Sep 5, 2015 01:33 AM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
