The car idles on 120-140mph?
Hi.
Yesterday, when I was driving my 02 TL-S on HWY, I hit 140mph... Yeah, I was crazy... Anyways, when I was on 120-140 range, it was rattling and shaking and felt unsafe. Would this be my axles bad? or I need wheel alignment or something?
thanks in advance.
thanks in advance.
If your car is heavy, then the cutoff comes in earlier, so was it redlining anytime just prior to it "idling"? if it was then its the computer that cut the fuel off, which is a safety measure. otherwise, maybe your fuel filter couldnt handle that flow rate, changing it may help you in your crazy escapades!!!
as for the fibration, odd are you have a tire out of balance, bent wheel, worn shock. it could be any # of things, but odds are its tire related
my car is smooth as glass at 145+
318whp/289wtq @ 6psi
Do you have stock rims on your car? Depending on what rating your tire is might be the problem if you car felt as if it was unsafe in the way you saying. I have went 145+ in mine without any problems but I do have "W" rated tires which are supposed to take like up to 168 mph or so...
Yes, I am on factory oem type-s rims..
My tires are toyo proxes.. I guess numerous things could effect this thing happen, but i felt my tl was like some cheap car when I was on 140 because of that rattling and dash board was rattling as well... I guess I have to check my axle, shocks, or something.. $$$
thanks for your help.
Comptech Freak
there must be sth wrong since u have rattles
or maybe the road is not smooth
@ slide or die @
First man, if its rattles and feels unsafe dont take it there. Second, its probably your wheel alignment because i really dont thing 3year old suspension parts can go bad (very unlikely) OR it could've been the road.
keep it safe yo!
*btw, know many members have gone even faster with no rattlin...it should be the other way around, smooth as your car is about to lift off!! (also now i'm 2nd in top speed -153 on my 99, lost to a guy who pushed to over 155 on a '01...tough your -S is governed at 147)
if there is
keep it safe yo!
Originally Posted by dnd2984
hope theres no state troopers on this forum
Mike Bertram
09-10-2015 09:27 AM
