Can TLS CD Player Play MP3 format?
Old Aug 12, 2001 | 08:52 PM
Guest
Guest
Posts: n/a
Hi Guys,
Is the CD player in the TLS MP3 compatible? For example, I have created MP3 CDs on my computers' CD burner. Will these play in the Acura CD player? I have not been able to make them play in the CD player of the Toyota Camry that I presently own.
Thanks,
Vasant.
Old Aug 12, 2001 | 08:59 PM
oracion's Avatar
Lightbulb
No. Those are just plain CD players.
Old Aug 12, 2001 | 09:07 PM
rockinTLS's Avatar
The Acura CD player is not an MP3 player. What this means is that raw .MP3 files that have not been converted to .CDA format will not play.
However, if you mean .MP3 files that have been converted to .CDA format and burned onto a CD-R using software like Adaptec CD-Creator, Nero or similar, yes they will work. They must be CD-R's, CD-RW's will not work. Also, paper labels are not recommended. They can peel off with the heat and jam the unit.
Old Aug 13, 2001 | 11:14 AM
Good info rockinTLS. I burn most of my CD's and use Fellowes Labels on them. They have not malfunctioned in the CD player. FYI
Old Aug 13, 2001 | 11:21 AM
rockinTLS's Avatar
Be careful, especially in the Florida heat. I write directly on the CD. Not worth the risk in my opinion.
Old Aug 14, 2001 | 04:07 PM
pianoman41's Avatar
Actually I discovered the heat isn't so much the problem as the "thickness" of the CD once the label is applied. The motor on the stock head unit is so weak it can barely grunt out a regular CD. When the label is on there it will really bog down and more often than not it won't spit it out.
Old Aug 14, 2001 | 05:26 PM
my2sense's Avatar
f-a-b-o-l-o-u-s
yes.. is it at all possible to put headers on the head unit motor? I feel that improved air flow will result in higher track speeds...
Jul 16, 2017 07:33 AM
Fool
Mar 10, 2016 08:42 PM
navtool.com
Sponsored Sales & Group Buys
87
Jan 23, 2016 01:25 PM
hashbrown
Sep 29, 2015 12:13 PM
08_UA7_Gr33k
Sep 27, 2015 12:42 PM
