Can I program the key myself?
Old Feb 25, 2005 | 02:01 PM
summerlun's Avatar
Just read a thread about programming the key without going to the dealer. Not sure if it works. Have anyone tried this before?
https://acurazine.com/forums/showthr...ilizer+program
this is a long process, but heres what you will need
your new key
a MASTER KEY (one with the remote in it)already programmed to car.
to program the transponder- (thats the immobilizer part)
sitting in dr. seat, put the master key in ignition, and turn to on.engine OFF. press the gas pedal 5 times to floor and release. now press brake 6 times (press and release)
remove master key from ignition. install new key and turn to on...engine off. press gas to floor once. now wait. the security light will blink for about 45-60 seconds, then it will go off if you did it correctly. once the light is off, car should start.
Old Feb 25, 2005 | 08:41 PM
etxxz's Avatar
@ slide or die @
can't be a "master key" it has to be cut first...and only the dealership can do this. If you have the key (ebay or watever) the dealer charges $5 to cut and program...or $40 for the key and the programming
if its a remote in the other hand, you can get em VERY cheap from ebay and program them youself. i have instructions if you need.
Old Feb 25, 2005 | 08:44 PM
take283's Avatar
Can u send me th instructions. I got the remote but not sure how to program it
Old Feb 25, 2005 | 11:16 PM
summerlun's Avatar
I went to plaza auto mall (acura dealer) in Brooklyn , they qoute me $25 for the key and $70 to program and cut.
soupi
14
Nov 15, 2015 11:15 AM
eastcoastguy
Oct 29, 2015 03:00 PM
joflewbyu2
Oct 8, 2015 11:16 AM
malvothegreat
Sep 29, 2015 12:38 AM
Sue1910
2G CL Problems & Fixes
Sep 27, 2015 12:34 PM
