Can I get rid of this??
can i get rid of this tube and replace it with one of those little breather filters where the circle is? will it affect anything? what exactly is it for? the tube goes into the valve cover.
im getting a 6 speed p2r intake made because i removed my vsa already and i wanted to tell Sean not to put in that nipple so it'll look cleaner
any info is appreciated
Autozone
its just a generic filter and one of these to plug in the hoses
http://www.autozone.com/autozone/cat...ndName=Spectre
just a temporary solution until i get a real intake
its just a generic filter and one of these to plug in the hoses http://www.autozone.com/autozone/cat...ndName=Spectre
thats the PCV crankcase ventilation--there is pressure inside the lower end of the engine thats released,, along with partially unburnt fuel and oil vapors,,routed back to the intake pipe and thru the intake manifold for reburning
Removal would allow vapors into the air, the aftermarket type filter part just catches the oil
Not legal in smog test states
I'm running a breather (small filter) now. No problems. If ur state opens ur hood of emissions u will fail. But if they just hook up tpo the obd2 port. U will be in the clear. I caped off the hole in the intake tube so all is good. U also have one of those hoses in the back.
that PCV is why you have to clean the TB throttle/air plate--its blowing an oily mess onto the metal surface and pivot pin.
Some carb cleaner takes care of that problem, and lube the throttle mechanism while you are there
I see, I see. Well I just cleaned my entire IM, EGR and TB a few weeks ago so I guess I should put in that catch can asap! Thanks guys
since we're on the subject, where does the hose on the other side of the intake go to?
Bonki' Ehrite!
Where can I get a breather? And do you have to empty it every now and then, or how does that work?
Bonki' Ehrite!
but it is one MORE thing to maintain/keep clean, also by doing that filter you are more likely to smell oil/exhaust/fuel fumes, etc. etc, because all that crap won't be reburned by the engine
(my 4 cents
(my 4 cents
looks like that's goin in with my intake
