Camber Kit
Tri State ViP Crew
Camber Kit
whats a good camber kit the car is ten years old so not trying to spend to much i have the H&R springs which i get some uneven wear or i should just keep going without it after all these years thanks
Check out RockAuto.com for Moog parts. There are other more expensive brands, but ya don't want something too cheap off Fleabay !
our sponsors excelerate and mrheeltoe carry quality brands of Adjustable camber kits
the question is- what is your negative camber now?
if less than 1.4 degree neg, little tire wear is present
more than that and expect wear,, or go for kits
usually its rear goes past limits unless way dropped, then both
did you keep up with alignment? was that the real issue?
mine wasnt kept right and wore out front tires
but I also dont rotate tires- preferring to buy 2 at a time~
a bit of neg camber in front makes it turn in better to the apex
Former Sponsor
I'd recommend the INGALLS kit for the rear. It includes an arm for camber and for toe. If you have a 03 TL though we will need to know if the arms you have are equal length or unequal length. I've linked both options below. Email us for more info if you want to order at sales@excelerateperformance.com
http://store.excelerateperformance.c...0/i-60219.aspx
http://store.excelerateperformance.c...5/i-60220.aspx
Tri State ViP Crew
since my last alignment my tires were wearing bad so i was curious but all the bad roads here alignment goes bad quick so i had to change the tires also belts busted and making noise
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
