In cabin filter
Old Jun 11, 2004 | 07:02 PM
steve's Avatar
In cabin filter
2003 type S with 23K and in use for 22 months. When do you suggest changing the in cabin air filter and is this a DIY job?
Old Jun 11, 2004 | 07:13 PM
fsttyms1's Avatar
yes very easy, wouldnt hurt to check them on occasion. you will have to pull out the glove box(very easy) then there is a small area behind it (once removed) that you have to cut the tabs on a piece of plastic to remove. (you will see what i mean) then once cut out you can pull the fiters out. the piece you cut out has a tab on it that hooks on and you use the screw thats already there to refasten it.
(sorry for the crude and fast instructions i couldnt find the DIY for it and im reciting it off the top of my head, its been like 1-1/2 years since i did it and know it really needs to be done)
its not as hard as it sounds
Old Jun 12, 2004 | 07:56 PM
figueroa1357's Avatar
yea i just did mine for the second time it took me 10 min max \
Old Jun 12, 2004 | 11:06 PM
NYDesi80's Avatar
Yeah.... I heard its not that hard, but can anyone suggest a good time to actually change it??
Old Jun 13, 2004 | 08:59 AM
fsttyms1's Avatar
i would check/replace (if necessary)once a year
Old Jun 13, 2004 | 09:36 AM
DeathtoToasters's Avatar
Where do you buy replacement filters?
Old Jun 13, 2004 | 11:44 AM
cljw's Avatar
Most auto parts stores can order them for you. I know Fram's part number is CF8603. You will need 2 of them. Cost is about $25 for both. Also the dealership has them in stock about for about the same price.
Replacement is easy just take your time when you do it the first time.
There is a piston on the righthand side of the glovebox - remove the screw and move the piston out of the way.
Pop off the two stops on the inside of the glove box - These take a little work but come off easily. The box will now open completely exposing the two screws that hold the bottom of the box to the dash. Remove those and the entire glove box will drop free of the dash.
You will then see the panel that needs to be cut out. remove that and you will have access to the filters. The filters are in a palstic holder that slides out. When replacing follow the airflow arrows.
The panel that you cut out is held back in place by clips and screws that are there.
I just did mind for the first time and it took less than 20 minutes
Old Jun 13, 2004 | 06:02 PM
yea evrey 30k or 16 months thats the method i use
Old Jun 13, 2004 | 06:37 PM
So what difference am I going to notice?
Old Jun 13, 2004 | 07:10 PM
well depending on how dirty it is it will increase the amount of air blowwing out
Old Jun 13, 2004 | 07:32 PM
13.95 each .....
http://www.cabinairfilters.net/cabin...m#Installation
Enjoy
Old Jun 13, 2004 | 10:00 PM
tweedle99's Avatar
They were 10.95 each at NAPA.
Old Oct 26, 2004 | 04:28 PM
firepepper's Avatar
Speaker City Rocks
fram instructions
http://www.fram.com/tech/CF8603Installation.pdf
Old Oct 27, 2004 | 01:40 PM
The hardest part of replacing the in-cabin filter is probably removing the rubber stops on the sides of the glove compartment or snipping off the plastic edges that hold the cover in front of the filters.
Old Oct 28, 2004 | 12:06 AM
johnny--2k's Avatar
My Daily Driver
I agree....
Old Jan 25, 2006 | 11:29 AM
jinharry's Avatar
Removing the Stops on the glove box
Can someone clarify EXACTLY which way those stops come off? Do you just push on the outside until they pop in or is there some sort of sliding/twisting involved?
Thanks!
2003 TL-Type S
Old Jan 25, 2006 | 12:03 PM
fsttyms1's Avatar
Are you talking the 2 black pieces on the sides? i just used a flathead screwdriver ad poped them up
here check this link. It has a great DIY
https://acurazine.com/forums/showthr...t=cabin+filter
Old Jan 25, 2006 | 12:35 PM
acutee's Avatar
With the mileage you have on your car, I wouldn't worry about changing the carbin filter. I believe the manual said to check every 30k.
Old Jan 25, 2006 | 02:00 PM
jinharry's Avatar
Thanks for the link!
Thanks for posting the link with pictures. I didn't see that one during my search.
Old Jan 25, 2006 | 02:01 PM
fsttyms1's Avatar
You dont need mileage to change or inspect those. Id recomend checking them fairly often. they get dirty fast if you use your vent/ac/heater system often.
No Problem
Old Jan 25, 2006 | 10:10 PM
Luke7's Avatar
WNC Real Estate Sales99TL
This link is great. I bought mine (a Pair) at Autozone for ? if I remember right about $16.00 = Bosch filters- The old ones had about 15,000 miles on em and they were dirty. I plan on changing them yearly.
They had been replaced at 30,000 miles. I just decided to do it again at 45,000. Beats the $80.00 charge at the Acura Dealer.
Old Jan 26, 2006 | 03:09 PM
bkzjimmy's Avatar
NiGhT rIdEr
real easy job........just dont drop one of the stoppers inside the glovebox hole like i did
Old Jan 26, 2006 | 03:14 PM
tweedle99's Avatar
$80, you got it cheap. My brother went to a local dealer and they wanted $120. for 10 min job and $20 worth of parts!!
Old Feb 22, 2006 | 06:18 AM
Luke7's Avatar
Mine were really dirty with only 15,000 miles on them. I will be replacing them yearly.
Old Feb 22, 2006 | 04:46 PM
green t el's Avatar
How dirty the filters get is a function of the dust, pollen, soot in the air where your car is driven. Get a good green springtime and the pollen will be all over the place. For the $22 list at Pep Boys (less 20% off coupon last week) once a year is more than reasonable.
Old Feb 22, 2006 | 05:28 PM
fsttyms1's Avatar
I replace mine yearly too, Come to think of it its abought that time maybe ill do it when i rip the dash apart to do teh 6 speed conversion
Old Feb 22, 2006 | 09:36 PM
Luke7's Avatar
My Bosch filters didn't even cost 20 bucks.
Old Feb 22, 2006 | 09:45 PM
htowndepsi's Avatar
Bosh, from Autozone for $12.95. I just bought it today and did it. I have just posted pics in the Pic gallery
Old Feb 25, 2006 | 05:04 PM
kuni808's Avatar
In 702, 808 in Dreams
Finally i replaced mine. i guess the guy who previously owned my TL did not know anythign about it. when i bought it it had about 42k i have 50k now and it was never changed. man i took it out it was BLACK. pretty grose. never been changed. fresher air and more powerful haha.
rcs86
Aug 2, 2016 06:52 PM
knight rider
Mar 4, 2016 08:59 AM
LeVeL
Oct 18, 2015 04:19 PM
steve
Sep 30, 2015 09:23 PM
merc009
Sep 29, 2015 03:06 PM
