In cabin filter
yes very easy, wouldnt hurt to check them on occasion. you will have to pull out the glove box(very easy) then there is a small area behind it (once removed) that you have to cut the tabs on a piece of plastic to remove. (you will see what i mean) then once cut out you can pull the fiters out. the piece you cut out has a tab on it that hooks on and you use the screw thats already there to refasten it.
(sorry for the crude and fast instructions i couldnt find the DIY for it and im reciting it off the top of my head, its been like 1-1/2 years since i did it and know it really needs to be done)
its not as hard as it sounds
Originally Posted by steve
2003 type S with 23K and in use for 22 months. When do you suggest changing the in cabin air filter and is this a DIY job?
Originally Posted by NYDesi80
Yeah.... I heard its not that hard, but can anyone suggest a good time to actually change it??
Most auto parts stores can order them for you. I know Fram's part number is CF8603. You will need 2 of them. Cost is about $25 for both. Also the dealership has them in stock about for about the same price.
Replacement is easy just take your time when you do it the first time.
There is a piston on the righthand side of the glovebox - remove the screw and move the piston out of the way.
Pop off the two stops on the inside of the glove box - These take a little work but come off easily. The box will now open completely exposing the two screws that hold the bottom of the box to the dash. Remove those and the entire glove box will drop free of the dash.
You will then see the panel that needs to be cut out. remove that and you will have access to the filters. The filters are in a palstic holder that slides out. When replacing follow the airflow arrows.
The panel that you cut out is held back in place by clips and screws that are there.
I just did mind for the first time and it took less than 20 minutes
Speaker City Rocks
The hardest part of replacing the in-cabin filter is probably removing the rubber stops on the sides of the glove compartment or snipping off the plastic edges that hold the cover in front of the filters.
Removing the Stops on the glove box
Can someone clarify EXACTLY which way those stops come off? Do you just push on the outside until they pop in or is there some sort of sliding/twisting involved?
Thanks!
2003 TL-Type S
Thanks!
2003 TL-Type S
Are you talking the 2 black pieces on the sides? i just used a flathead screwdriver ad poped them up
here check this link. It has a great DIY
https://acurazine.com/forums/showthr...t=cabin+filter
Originally Posted by acutee
With the mileage you have on your car, I wouldn't worry about changing the carbin filter. I believe the manual said to check every 30k.
Originally Posted by jinharry
Thanks for posting the link with pictures. I didn't see that one during my search.
WNC Real Estate Sales99TL
They had been replaced at 30,000 miles. I just decided to do it again at 45,000. Beats the $80.00 charge at the Acura Dealer.
Originally Posted by Luke7
This link is great. I bought mine (a Pair) at Autozone for ? if I remember right about $16.00 = Bosch filters- The old ones had about 15,000 miles on em and they were dirty. I plan on changing them yearly.
How dirty the filters get is a function of the dust, pollen, soot in the air where your car is driven. Get a good green springtime and the pollen will be all over the place. For the $22 list at Pep Boys (less 20% off coupon last week) once a year is more than reasonable.
Mine were really dirty with only 15,000 miles on them. I will be replacing them yearly.
Originally Posted by tweedle99
$80, you got it cheap. My brother went to a local dealer and they wanted $120. for 10 min job and $20 worth of parts!!
In 702, 808 in Dreams
Finally i replaced mine. i guess the guy who previously owned my TL did not know anythign about it. when i bought it it had about 42k i have 50k now and it was never changed. man i took it out it was BLACK. pretty grose. never been changed. fresher air and more powerful haha.
rcs86
08-02-2016 06:52 PM
