A/C Drain Leakage
A/C Drain Leakage
Can someone tell me if thay have any idea ho to remove a clog from the a/c condesor. My 99 tl is leaking in the passenger side floor and I can not remove the plasric housing around it. Thanks for the help.
Does it leak in there during/after a rain storm or while you use your ac/heat?
If its leaking when you use your ac/heat then its your blower motor or connections going to it. The blower motor is what turns on the electric fan in the the ac/heating system.
I forgot to mention that it could be the evaporator core , but im not 100% sure since it make specific. Every manufacture designs their ac/heating system differently.The best way to tell is remove everything from that are & visually inspect. There has to be a way to remove the plastic covering from that are. You might need to remove the glove box first.
This is where a helms manual comes in handy.
Stay Out Of the Left Lane
Biggie_B
May 27, 2025 05:51 PM
MetalGearTypeS
Aug 29, 2016 08:28 PM
