Bypass(fake) the computer question????
Old Mar 22, 2007 | 05:33 PM
InspireUA5's Avatar
極品インスパイア32V
Exclamation Bypass(fake) the computer question????
Hi,
Does anyone how I can bypass the computer on my car that my screen can still play the video while my foot brake is released?
Thanks.
Old Mar 22, 2007 | 05:52 PM
dutty-07's Avatar
you are speaking of an aftermarket unit correct?? I'm not familiar w/ the factory screen, as i dont have the navi. Anywayz bypassing aftermarket units vary depending on the unit. with some of the older units, u can simply ground out the parking brake wire, some of the newer ones u can add a switch to it and then it gets even more advanced, requiring soldering and such. One universal trick that works on most units, even the newer units, is simply pushing the e-brake down enough for the light to come on, but not enough to actually make a dif.
Old Mar 22, 2007 | 06:19 PM
InspireUA5's Avatar
極品インスパイア32V
Yes I am speaking of the aftermarket unit.
what do you mean by "pushing the e-brake down enough for the light to come on, but not enough to actually make a dif"? that one doesn't solve the problem, does it?
Old Mar 22, 2007 | 06:46 PM
dutty-07's Avatar
exactly which unit do u have because there is no one universal solution. Different units are bypassed differently. and what i meant was just push the e-brake down one click, just until the BRAKE light on ur cluster comes on, but dont push the brake down all the way for it to grip the rotors. Im not sure if it would work w/ our cars, but on most cars it works. im in class right now, but when i get out ill check and see if itll work in our cars.
Old Mar 22, 2007 | 08:25 PM
@cUr@-TL's Avatar
'99 Acura 3.2TL
usually the e-brake "protection" is a ground trigger... just wire the e-brake wire from your headunit to the ground wire and you'll be able to watch your screen anytime...
what model is your HU ?
Old Mar 22, 2007 | 09:01 PM
disgookonfiya's Avatar
it would help if you told us what kind go head unit you have... most older models, you can just ground the parking brake wire, and it'll work. Alpine i believe requires a bypass, and all the pioneer info u need can probably be found on avic411
Old Mar 23, 2007 | 08:48 AM
InspireUA5's Avatar
極品インスパイア32V
I have Pioneer 6800DVD
Old Mar 23, 2007 | 06:55 PM
InspireUA5's Avatar
極品インスパイア32V
anyone know?
Old Mar 24, 2007 | 11:20 AM
EL19's Avatar
just ground out the wire thats supposed to be connected to the ground on the parking brake..
Old Mar 24, 2007 | 04:30 PM
TL-A-Spec's Avatar
^^ exactly what i did
Old Mar 25, 2007 | 09:01 AM
InspireUA5's Avatar
極品インスパイア32V
Can you show what exactly I need to do? e.g. DIY step by step? Also pictures would help, thanks.
Old Mar 26, 2007 | 07:45 AM
dutty-07's Avatar
just tie the parking brake wire onto the ground wire and ur done. thats a nice unit by the way.
Old Mar 26, 2007 | 10:01 PM
Phrosttz0's Avatar
x2, i have a kenwood ddx7017 if that helps
Old Mar 26, 2007 | 10:50 PM
dutty-07's Avatar
ok sorry i lied, i think for the 6800dvd u hav to hook u[ the parking brake wire to a switch. just put one side of the switch to ground and the other side to the parking brake wire. i think it needs a pulsed ground signal.
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
Username 0
2G TSX Performance Parts & Modifications
23
Sep 28, 2015 09:09 AM
navtool.com
Sep 25, 2015 05:15 PM
