broken motor mount NEED ADVICE
I got a 99 Acura Tl with 150,000 miles plus!
What does a mechanic need to do to replace/fix a broken right side motor mount??
How much is the part itself ususally? Any links to buy the part? Thanks in advance!
How much does a mechanic charge to buy the part and do it for you usually? Again side motormount
https://acurazine.com/forums/2g-tl-problems-fixes-117/broken-motor-mount-need-advice-747686/
What's wrong with the thread that you already started about this?
![Repost](https://acurazine.com/forums/images/smilies/repost.gif)
right side mount about half an hour and 50 bucks for the part
See any of our dealership vendors for the right stuff
I would be surprised to find a side mount broken without the front being broken too- it usually goes out first, then the extra strain on the side mount breaks it
Its 150$ part!! plus up to 2 hours labor at shops to replace
DIY list has the procedure and tools shown for the job
Hi luxerymobile :
Look in the DIY section and you will find detailed replacement instructions for both front and side mounts. I know this because I successfully changed mine using this guide. Also, if you use the search feature you'll find even more info.
Good luck !
smartypants
Good luck !
smartypants
joflewbyu2
10-08-2015 11:16 AM
