brembo GT kit
Originally Posted by car_lost
yup, you need 18" wheels to clear it. the smaller one should clear wtih a 5mm spacer.
there are 2 kits. one is larger than the other one. 1 of them requires a 5mm spacer between the wheel and the rotor for clearance, the other requires a larger wheel. some 17's wont clear the smaller of the 2 also.
Originally Posted by samkws
oh...damn
what is a spacers btw?
is there a lot of job to be done if i do a 5mm spacer?
will fit the 13in kit? that's the larger one...
for the 13" kit you need 18" wheels.
OH...=(
not even my silver star TSX wheels? they should clear more than the stock TL-S rims
for the regular brembo bbk (the smaller one) you can use 17" wheels but you will need a spacer... most likely 5mm spacers. the spacers will push the wheel out to give more clearance for the bigger calipers.
for the larger brembo bbk you will need a minimum of 18" wheels.
Comptech Freak
ok but you can get the smaller bbk. theres not much difference between them.
i won't buy bbk at orginal, 2500 dollasr!!!
now i will just get some rotoras instead, a set of 4
i saw a set of GT kit selling for cheap, that's y i am considering
I bought the Rotora BBK and am hoping they will fit under my 17" rims off a 3rd Gen. Eclipse. Since they're just crappy Mitsu. factory rims, I won't be heartbroken of they don't fit, but I can't even test them since I can't get the f**king stock rotors off the car to test the fit. I hammered the little screws with an impact wrench until I destroyed one of the bits and got nowhere... I'll try PB Blaster to loosen them up, but I'd really like to know if I need to go rim shopping in order to fit these brakes....
Dirk
Dirk
Dirk
Dirk
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
