Break related Servicing Questions
Old Jun 18, 2007 | 12:21 PM
newbie's Avatar
1. The "Break Lamp" light comes on now (everytime after I step on the break after car starts, and remains on). Most likely I need to change the bulbs. I tried to search and look for the DIY for changing the bulbs, but could not find anything (maybe it's just too easy?). Could someone point me to it? Also, where do you guys get the bulbs and for how much.
2. Break pads. I am running the Rotora slotted with the Satisfied Pro pads, and they have been squeaking a bit since I had them, this is quite annoying, but more importantly it becomes a bit harder to tell if it's the "warning squeak" when the Pads are running out. Whenever I take my car to the dealer they usually will tell me how much break pad is left, but I have decided that I can't fully trust them (since sometime they will say that 30% remaining but the next time I bring it in it will become 50% remaining...). What is the proper way to check how much break pad is left?
Old Jun 18, 2007 | 12:25 PM
Trackruner228's Avatar
1. I am pretty sure the book that came with the car will tell you how to fix that.
2. As far as brake pads I would say next time your tires are off your car look for yourself.
Old Jun 18, 2007 | 12:38 PM
newbie's Avatar
Thank you. I found the instruction in the manual like you suggested.
As for the break pad check. Is there anyway to do it w/o removing the tires? I assume that there's got to be a way, right?
Old Jun 18, 2007 | 12:56 PM
6spMike's Avatar
Mike's Silver Bullet
If you can see the metal 'squealer', check how much distance there is between that and the rotor surface.
Old Jun 18, 2007 | 01:17 PM
fsttyms1's Avatar
Take your pads off or have them taken off and have the anti squeal applied to the back of the pads. There is no way to inspect the pads correctly with the tire on.
Also try Bedding them in to see if that makes it go away
Also its BRAKE. You arent Breaking any thing
Old Jun 18, 2007 | 02:37 PM
01tl4tl's Avatar
Unless they dont Brake!!!!
Old Jun 18, 2007 | 03:06 PM
newbie's Avatar
wow, don't I feel like an idiot! nice.
Old Jun 18, 2007 | 03:17 PM
fsttyms1's Avatar
then i would say they were Broke
Old Jun 18, 2007 | 06:50 PM
Black_Tl_S's Avatar
Resident Ford Tech
either:
1 - brake fluid is low
2 - Low pad life left
Old Jun 18, 2007 | 06:59 PM
01tl4tl's Avatar
The Brake LAMP light was the prob- that means a bulb is out
The other Brake Warning Light is for above problems
Old Jun 19, 2007 | 06:57 AM
SatinSilverTypS's Avatar
ChairmanMaoSaysRTFM
did you grease the pad-caliper contact surfaces? that will make all the difference for the squeaking noises.
Old Jun 19, 2007 | 08:32 AM
sistom's Avatar
pwnage
lolz
vaughanml2
Nov 1, 2021 10:16 AM
Feb 25, 2020 09:57 AM
Sep 17, 2015 10:16 AM
datadr
Sep 12, 2015 09:12 PM
MyGuti
Sep 12, 2015 06:52 PM
