Brakes issue
Brakes issue
Has anyone ran into uneven brake pad wear causing vibration with hawk pads ? I cant seem to figure out my vibration when i touch the brakes. so far new hps front and rear, new front powerslot rotors and re surfaced rears. Ive switched tires front to rear tire pressure is normal. Could id be anything to do with an alignment or wheel balancing?
I bet its your hps rear pads
they are known to have a 3rd raised tab in the inner pad for rears
that extra tab in `top center` touches the piston first and makes pad extend crooked
you can tell by looking at the inside of rotor for half rusty half shiny width and the pad wear will be at an angle on the top to bottem of pad
grind off extra tab FLUSH and it will be ok
beyond that reck all brake sliders are clean and greased- the caliper pins are free and all torques are correct
too tight on calipers can be weird probs too
how is the alignment- toe out can shake the front with braking
I will take a look at all that and i tear it all apart and check the front as well. Im going to take it in for an alignment and wheel balance to see if it gets rid of this as well. thanks for the in site on the rear hawks
ck rear brakes before alignment shop inspection
you flushed the brake fluid to get rid of crud?
you are seeing uneven wear already? where?
takin care of Business in
Received 4,732 Likes
damn bro....you hit the nail on the head !!!
Uneven wear means caliper/pad is getting Hung up. Fix that, get new pads and vibrations will go away (may need new rotors too)
Check the Rubber things (The ones on the Sliders) on the Calipers if they dont hold vacuum they need to be replaced... Common issue for Sticky Calipers... Happened before on my Rear Calipers.
those pins are supposed to be greased so the caliper slides easily on them,
boots protect grease,, same as cv boots protect that area
vac inside there affecting braking? not that I am aware~
thats a good point Mobb
always ck the center hub and the hub plate where rotor sits on
any crud buildup there can cause an offset during mounting!
a little sandpaper and some brake grease there is a good plan
Im still going with: hawk has the 3rd tab on inner rear pads as a culprit for unusual braking with new parts,,I had it is how I know!
well took apart the rear and the inside pads as stated was only contacting on part of the pad due to the 3rd raised tab. thanks very much i would of never suspected that at all.
grind it down flush, below the spacers, so for sure it doesnt hit
if pad wear is too severe to self correct with full use, contact hawk or seller for exchange, I did- and notified them of this prob more than a year ago
The Sliders should come back when Installed if you take the Holding Bracket and remove the Slider and put it back in, It should hold Vac the Boot should inflate and Turn Back by itself its a simple test to know if the Boots are Damaged.
Also worn boots or Pinched Boots make the Grease gets dry or get Dirt and Fails, Same as CV Boots.
01tl4tl (07-29-2011)
mada51589
05-03-2022 08:54 PM
