Brakes DIY?
removing the whole brake assembly, bleeding, changing rotors/pads, bbk upgrade, pakring brake addjustment...what exactly are you looking for....brakes are not something a diy could really be made for...you have to know what your doing
Originally Posted by fsttyms1
remove 2 bolts that hold caliper on. get a big C clamp push in the piston insert new pads and reassemble. start car and pump brakes a few times. brakes are not hard to do at all
you can bolt it back into place (with 1 or both bolts depending on what you have to use to pry)with out the pads on, then if you have a flat pry bar you can push it back into place. it shouldnt be that hard to press back in. if you can find a big set of channel locks you can use them too. run to walmart, or just about any parts store. they should be open and have something.
thanks man, maybe i can just run to autozone and pick up the c clamp. i went there today and not a single person had any idea what a impact screwdriver was. i felt like smaking them.
i did mine today i got slotted drilled rotors put in and new axiss brake pads need to break them in so far so good i loke the way they look. Should have painted my brakes red while i was at it but oh well easy project with the help of my cousin who is a mechanic. impact screwdriver very important.
In Pursuit of Perfection
yea u got pretty much everything down, remove the calipers, take out old brake pads, use c clamp or if u dont have one use ne thing flat and gently hammer the piston down. dont forget to remove the metal protectors or whatever they are that are on the orginal brake pads and put them on the new ones. each brake pad should have 1 metal peice that goes around the pad. also removing the brake fluid cap in the engine pay releases the air pressure so pushing back down the piston will be alot easier. after everything is done jus pump the brakes and your'e set.
here's an easy to follow diy
http://www..com/forums/showthread.php?s=&threadid=19636
good pics n everything
EDIT: Nevermind i got it
GWEEDOspeedo
Jan 15, 2016 10:39 PM
