Brakes
TWO-FOUR
Brakes
I Need New Rotors And Pads All The Way Around On My 02 Tl Type S. I Was Woundering If Anyone Has Checked Out The Performence Rotors At Forumracing.com And What You Think Of Them.
Any Info Welcome, Thanks
To many holes, which degrades the structural integrity of the rotor. If you want drilled then go with Irotors which have fewer holes + they don't really tell you specs on those "performance" rotors. They are probably a $15.00 Allsafe rotor that is drilled & slotted by a machine shop.
Also look into Rotora slotted.
TWO-FOUR
TWO-FOUR
ALONG WITH THE BEST PADS? THANKS
TWO-FOUR
Sippy Cup (x2)
Originally Posted by TWO-FOUR
JUST ASKING HOW DO YOU FIGURE THEY HAVE TO MANY HOLES THERES NAME BRAND CROSS DRILLED ROTORS THAT IVE SEEN THAT HAVE PROBABLY MORE HOLES THEN THAT. WHOULDNT THE OTHERS WITH MORE HOLES BE MORE DEGRADING TO THEIR INTEGRITY. AT LEAST THESE HAVE A WARENTY. I DONT THINK ANY OTHERS IVE SEEN HAVE.
All rotors start their life as blanks & then have slots or holes drilled into them by either the manufacture or someone else. There are companies that buy these "name brand" rotors and have holes drilled into them.
Why do you think these companies drill holes in the rotors for, structural integrity or looks?
I don't know what length of the warranty is (90 days, 500 miles etc) the warranty is worthless IMO & they all have some kind of warranty. First off, those drilled rotors will crack after 90 days. Second, you will spend a lot of time & money removing them and paying to ship them back.
This is to many holes
This is acceptible
![](http://www.ls1tech.com/02Camaro/images/iRotors.jpg)
These are dimple drilled, meaning they are not drilled all the way through
![](http://www.nolimitmotorsport.com/2/powerslot-prostop.jpg)
I would also consider cryo treating at least your front rotors if you do go drilled.
Here are brand names:
Rotora
Irotor
Power Slot
Brembo
Zimmermann
Heres a good article on rotors: http://www.aa1car.com/library/2003/bf10312.htm
![](http://www.carmotorsports.com/images/Brake%20Rotors%20drilled.gif)
This is acceptible
Rotora
Irotor
Power Slot
Brembo
Zimmermann
Former Sponsor
www.ROTORA.com
You will find many members on this site running ROTORA slotted rotors. They reduce brake fade, brake well, and are not prone to warping like the stock rotors.
If you need rotors PM me with your zip code for prices.
Just chillen..
Well, I was doing some online searching and came upon this, what do you guys think? I think they are good for the price and arent drilled.. http://www.autocarparts.com/part/1470/0
I found a Brembo rotor the plain one from tirerack.com and it's quite cheap like $65 (I know it's just plain not slotted nor drilled) but it's quite cheap...what do u guys think? no good?
Rotora
Irotors
You can get the Irotors as slotted only. Just let them know when you order.
The Brembos are the same price as the Irotors + people have had some issues with the Brembos warping, just do a search on here. IMO I would go with Irotors before Brembo unless you cryo treat them, then it doesn't realy matter which one you get.
TWO-FOUR
Originally Posted by JMAL
nobody mentions powerslot. is there a reason?
Rotora
Irotor
Power Slot
Brembo
Zimmermann
Rotora
Irotor
Power Slot
Brembo
Zimmermann
no i meant in like a review manner. everyone always has rotora or irotor. besides it being listed in that particular list, i never hear anything about it. i was curious if anyone actually owns the powerslots and can actually talk about them.
3rd Gear
Power Slot Cryo's at AutoAnything.Com
I just placed my order from AutoAnything.COM for a front set of Power Slot Cryo's and Hawk HPS brake pads. Price was much better than Tire Rack and I had a 10% off coupon and free shipping. Total for 2 rotors and pads delivered was under $300.
AutoAnything Graphic
I'll let you know how these work out for me.
GWEEDOspeedo
01-15-2016 10:39 PM
lanechanger
10-13-2015 10:56 AM
