Brake Upgrade
Old Feb 19, 2008 | 10:19 PM
demetri's Avatar
Brake Upgrade
Has anyone else updated their brake calipers with the the Legend 2 piston type?
https://acurazine.com/forums/showthr...t=rotora+brake
850EX any news to report after the conversion? Is it a noticeable difference?
any pics?
thanks
Old Feb 20, 2008 | 12:17 AM
merkin110's Avatar
Do a search. There are many people on this forum who has done this. Hopefully I will be doing this soon as well.
Old Feb 20, 2008 | 01:10 AM
01tl4tl's Avatar
Search for post under my name
Its a straight up install- is a major increase in braking force, and is what should have come on the TL, IMO
Old Feb 20, 2008 | 06:15 AM
Luke7's Avatar
WNC Real Estate Sales99TL
I see there are new brake lines? What kind? Where did you get them? I'm updating my front brakes soon.
Thanks!
Old Feb 20, 2008 | 09:35 AM
fsttyms1's Avatar
Thanks!
SS lines. Order them from our vendors or online.
Old Feb 20, 2008 | 10:16 AM
01tl4tl's Avatar
I got the Stainless Steel brake lines- which are really a teflon flex tube wrapped in braided steel bands to protect it- gives more solid pedal feel and no more rubber hose expansion with heat and pressure.
Old Feb 20, 2008 | 10:38 AM
Blue_TL's Avatar
Aren't those RB rotors? Do they make any noise under heavy braking?
Old Feb 20, 2008 | 10:41 AM
01tl4tl's Avatar
Yes they are RB one piece rotors in front with their ET300 pads.
What is this noise people keep talking about. I didnt know the Hawks were noisy until I replaced them with ET300s
Al I hear under heavy braking is the road asphalt getting sucked off its base foundation~
Old Feb 20, 2008 | 10:56 AM
jjashaa's Avatar
Avant Garde Wheels
^ lol time for me to upgrade me brakes
Old Feb 20, 2008 | 12:09 PM
Blue_TL's Avatar
I get a whirring noise from my x-drilled slotted iRotors, no matter which pad I use. I have heard others complain about the same noise with other rotors. I plan on swapping them out at some point, they have nearly 30,000 on them now, and I will be looking for something that does not whir
Old Feb 20, 2008 | 12:31 PM
01tl4tl's Avatar
its the crossdrilling holes that makes the noise-thats a lot of on and off contact points with the pad as the rotors spins
regular side slots do what aggressive drivers need and are relatively quiet.
Old Feb 20, 2008 | 12:59 PM
derrick's Avatar
No apparent noise with the Racingbrake rotors + Hawk pads that MrHeelToe has been promoting... Maybe I'm just deaf or play the radio too loud ... LOL.
Old Feb 21, 2008 | 12:05 AM
loojoohnnyl's Avatar
i need new brakes but i am poor
Old Feb 22, 2008 | 11:39 AM
Blue_TL's Avatar
Damn crossdrilling. I thought for sure it was the slots.
Old Feb 22, 2008 | 11:43 AM
01tl4tl's Avatar
slots make a tiny bit of noise, but compared the the hundred+ holes each making air move thru and around the thing - some noise is a given.
Crossdrilled is great for autocross racing and supposed to be great in the wet.
Old Feb 22, 2008 | 02:10 PM
MurdaZ's Avatar
nice 01tl4tl....
OP, u can do the legend 2 piston, or the nsx 2 piston calipers...
nsx ones r nicer imo..
Old Feb 22, 2008 | 04:08 PM
01tl4tl's Avatar
When I was checking the size of the caliper piston- each pistons diameter relative to the other- the NSX had 1 much smaller, by several MM. This would be due to them running on the opposite side of the suspension- we swap them left to right for TL useage.
When used in the original direction - weight transfer and pad loading would equalize the pressure distribution across the pad face. Good for extreme braking~
Used backwards on the TL- having piston diameters as close to same is advantageous.
The 1995 LS Coupe was closest I could find, so thats what I used
If anyone has using nsx calipers and made an actual measure- please post.
Not having seen nsx calipers in person, I will say thet my Legends look great painted black!
Old Feb 29, 2008 | 02:48 PM
VIP typ-S's Avatar
I used Motul RBF600 brake fluid. That stuff is the BEST.
Jul 16, 2017 07:33 AM
GWEEDOspeedo
Jan 15, 2016 10:39 PM
lanechanger
Oct 13, 2015 10:56 AM
rockyboy
Oct 2, 2015 10:45 PM
