brake question?
brake question?
Hey guys quick question . I just got my 03 TL back from the body shop it was in the shop for 30 days. Its the 2nd day im driving it and when i press the brakes coming to a red light and I apply pressure to the brakes it feels like the brakes are pulsing.. sounds wierd right but when my foots on the brake i can feel it move my leg a little what could this be?
^^^if you dont hear any metal scraping when braking your pretty much safe, theres a pin on the pad to let you know when they are getting low
what was it in the shop for? they may of had to do work on the brakes and they didnt bleed it correctly and theres air in the lines, check the brake fluid level
is it actual ABS operation? or just worn out pad feel?
when the pads are low the caliper has to extend farther,,,doesnt like that
remove wheel and caliper to inspect properly
never trust the metal arm noise maker to signal low pads
It can get bent away,or missing, or you dont hear it
Metal on metal noise means you went past brake pad,,,
and are now experimenting with an advanced Flintstones system = no brakes!!
will need rotors to go with the new pads~
you could have a wheel speed sensor bad..wire torn loose etc--
was there front crash damage?
take it back to the shop and tell them its not right
those places dont test drive,,like a repair shop would
If brake bleed was done, they may not be aware of the special TL order= LF RF RR LR
My car was in the shop because it was side swiped on a side street. only rear quarter panel damage and rear bumper. No front damage. I changed my
front brakes 2 months ago but never changed my rotors (front + rear) since i bought the car 13 months ago
they may be the originals then,,front rotors being well known for shake as they age
Most of us go aftermarket and upgrade to performance rotors and pads,
if you enjoy driving in a spirited manner
you may need to bleed the brakes now, start with that and inspecting the parts.
Did you lube the caliper pins and the slider tab parts?
torque is spec on caliper bolts?
any bedding in done to brakes yet? plain or fancy pads?
cleaned rotors with sandpaper before new pads?
mada51589
Jan 9, 2025 04:40 PM
