brake lamp light
brake lamp light
today as i was driving my brake lamp light came on, my brake lights are working fine. i am confused. why would you think it came on. i only got 400 miles left on my warrenty also.
thanks.
thanks.
New Life
Like songoku said but check out this site: https://www.ahm-ownerlink.com/assets...man/2003tl.pdf go to page 66.
you might wanna check your brake fluid, i had the same problem, called the dealer , they said that we have a sensor in the cap that reads how much fluid in the master cylinder or it just might be loose
If it's the brake light in the instrument cluster that is coming on when drive the car then that probably isn't your rear break light bulbs. Take a look at the either the brake fluid level in the master cylinder or see if the parking brake is adjusted correctly.
^ agreed, i dont thinke we have a brake light indicator on the tl. if the brake light is on make sure the parking brake isnt slightly on or part of it stuck, also check the fluid. if you cant find any thing i would bring it to the dealer
my third light works perfect.
the light is next to the brake light
its called "Brake Lamp" .
i got a 2002tls
also i checked the fluid cap. its good.
i got a 2002tls
BlingBling INSPIRE 32V
Maybe you just didn't realize it.
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
rockyboy
08-04-2024 10:35 AM
mada51589
05-03-2022 08:54 PM
