"Brake Lamp"
"Brake Lamp"
I was driving to school yesterday, and looked down and thought to myself, "Come to think of it, I have never seen that light ever come on. I wonder if it even works?"
I park, and as I'm getting ready to get out of the car, GUESS WHAT? The light came on. It was pretty freaky.
Well, my far right taillight bulb is out. So, I have two questions.
1) What is the bulb size, or where do I get it?
2) I know that Halogen's lose their brightness with age. So, if I get a new bulb will it be noticeably brigher than the other 3?
Thanks to anyone who can answer, the search feature hates me.
we don't have halogen taillight bulbs, so brightness won't be an issue unless the glass bulbs are discolored or darkened..the auto parts store has a book to tell you the bulb number for every car, but it is 7443 for tail lights, also your owners manual provides that info. I always replace in pairs since the others may go out pretty much around the same time, at least in my experience..the come in pairs most of the time anyway
mine stays on permenantly
the harnesses that came with my inspire tails dont read the american bulbs right.. so im stuck with it unless i just sell my inspire tails and buy depot ones..
Got it done this Saturday. Wasn't hard at all. Bulbs cost like $6 for the pair.
1. Take out clips in the trunk trim piece. (The one that runs across the back bumper)
2. Remove trim piece. Takes 45 seconds.
3. Pull back trunk liner.
4. Grab bulb socket and rotate counter clockwise. After 1/4 turn, it should pop out.
5. Pull out burnt bulb and replace with new.
6. Reverse steps!
6. Reverse steps!
mines been on since i got the car. and i have replaced all bulbs with new ones... its just a wierd happening i guess..
When the light came on, I checked my taillights and none were burnt out.
If I had the lights on, all four bulbs lit up. Once you hit the brake, only 3 would get bright, and one would go out.
Maybe you are experiencing the same thing. You don't think you have one out because they all light up. Have someone press the brake for you and check the lights yourself with the brake pedal down. You'll see what I mean.
trick bulb= fancy bulb that cost more than regular bulbs..like most things for the TL~
When you check them due to brake lamp warning you MUST have someone step on the brake pedal
How else do you activate the circuit?
Also the center/3rd brake lamp,, has to work or the warning will trigger
all bulbs work just fine and light remains...
i've given up on it though.. hopefully the warning signal will burn out soon seeing how its on 24/7
I hope this is not permanent especially when nothing is actually wrong. I had my wife check out the lights while I pushed the brake pedal and she said they looked good. Maybe I need to have her push the brake instead and check it out myself. One thing I did do is swap the brake light bulbs for silver bulbs. Maybe this is the problem
have someone else push the brake pedal
Only YOU can see the 2 bulbs on each side for brakes and the 2 center deck mount
Is it the brake LAMP warning thats on?
If you put in lower resistance bulbs that will trigger it just like installing LED signals will make it think there is a bad bulb- lower resistance than it expects
gen2 are at an age for new tail bulbs and brake light bulbs and the headlight low beams
Its just that age and useage- bulbs grow dimmer, then fail
Replace in pairs
If a brake light do them all- they get the same use~
Replace in pairs
you can always use a stick or a board and wedge between the brake pedal and seat to turn on brake lights. I had a fake brake warning light, then I took out my 3rd brakelight bulbs, put them back in and it went away...the gremlin must of been hiding in the harness.
good ol Uncle Jitty always comin up with the old skool ways of gettin it done...
How do you get to the 3rd brakelight bulb? Already tried the search.
GWEEDOspeedo
01-15-2016 10:39 PM
lanechanger
10-13-2015 10:56 AM
