brake help!!!!
brake help!!!!
okay so im changing the rear pads and rotors as im already done with the front and the whole operation went smooth, but now the rear pads for some reason dont fit. I mean the pads are the right size but after i pushed the piston in the other half of the caliper that needs to squeeze in to allow the outer pad fit wont close enough to allow enough clearence for the new pad to slide over the rotor. help me please if anyone knows whats going on. is my caliper siezed or am i doing something wrong?
I have just changed my rear pads and rotors without having issues. Do you know how much more clearence is required for the new pads to slide into the caliper? If it was less than an inch, you could probably squeeze the caliper a little more.
Just my $0.02.
Just my $0.02.
Just my $0.02.
Just my $0.02.
Pull the Rubber boots and bolts that go thru the rubber boot and get some brake grease and lube them. Make sure they slide smoothly. If they arent moving smoothly they will need to be taken out and cleaned greased. those pins just slide out.
GWEEDOspeedo
Jan 15, 2016 10:39 PM
lanechanger
Oct 13, 2015 10:56 AM
rockyboy
Oct 2, 2015 10:45 PM
