Brake help!
Old Sep 26, 2004 | 08:19 AM
SSM-1's Avatar
4th Gear
Brake help!
I have a 2002 TL, and I'm changing out the rear pads. Got everything apart easy enough and got the new pads back in, but I can't quite get the caliper to compress far enough. I mean I got the piston back in, but it seems like the outside part of the caliper needs to be pushed in too. Any ideas? Thanks in advance!
Old Sep 26, 2004 | 08:58 AM
fpique's Avatar
NorCal you Beezy!
Yeah go to your auto parts store and get...
Go get a brake caliper spreader... $15
If not use a "C" clap and a piece of wood to press the piston back in.
Don't step on the brake or the piston will come out further.
Don't hit it with anything... I did that and ended up phluckin up my brakes
Old Sep 26, 2004 | 11:29 AM
SSM-1's Avatar
4th Gear
Cool thanks....I got it back together. I was being stupid, the whole outside moves, didn't notice it cause the spring clip holding the pads in I think. Now if I could just have gotten the #%#@ rotor off. Those screws are a b!tch. Didn't want to strip them...I tried WD40 and pounding the life out of them, but no go.
Old Sep 26, 2004 | 03:11 PM
TeknoKing's Avatar
IMPACT SCREWDRIVER does magic on the screws, if they do not move, do not strip them, you will need a torch to heat them up and remove them.
and yes, like mentioned above, the C-Clamp will do the job.
GWEEDOspeedo
Jan 15, 2016 10:39 PM
lanechanger
Oct 13, 2015 10:56 AM
rockyboy
Oct 2, 2015 10:45 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
2ManyHobbies
Sep 24, 2015 09:23 PM
