bottom end knock
Old Dec 9, 2011 | 09:01 PM
99a32tl's Avatar
7th Gear
bottom end knock
hey everyone,
a week ago i posted about a knock and i thought i would re-post saying that i have gone over everything that is a common issue on here and its 100% from the bottom end.
things that i have done,
valve clearance adjustment (some valves were out by 0.005")
egr port cleaning (was brutal)
new upper gaskets
new tensioner and belt (tensioner was seized solid, had to cut belt)
changed oil to 5w30
new pcv
new air filter
new spark plugs
1 new coil
fixed a couple coolant leaks due to rotted clamps
visually inspected timing belt and looks good to me
so by the looks of it my next step is to get the oil pan off and swap in some new bearings at the proper clearances
have you guys ever seen this?? i have been dealing with honda's for years and this is my first experience with bottom end knock, and its loud. was hoping to catch it before it does too much damage
any information would be great
thanks
Mike
Old Dec 9, 2011 | 10:18 PM
sammy95's Avatar
You're on the right path. Highly uncommon for these engines to develop bottom end noise, because clearance tolerances are so low that they don't wear out as our domestic cars.
Take that pan off and take a good look.
Old Dec 10, 2011 | 10:54 AM
01tl4tl's Avatar
One could assume an extended length of time between oil changes caused sludge--
zero maitenance,, and maybe this car was parked for some time as well?
was it a salvage or rebuilt title?
got the car cheap?
a mechanics stethascope will help listening to the oil pan
have to drop some subframe parts to remove oil pan
Have you tried seafoam in oil to clear all the passages and sludge?
have you done compression cks? and leakdown test if needed?
see if a cylinder has heat/scoring damage before you do the bottem end
What did the spark plugs show? (you seem to know engines and can read plugs or use charts online)
If compression shows any prob, it may be smarter to get a junkyard engine and slap all your new parts on it
What tensioner was seized--the ac belt? thats another sign this engine was treated really bad,,its hard to drive with that ac tensioner growling
Tbelt you cant really tell condition until its flipped inside out and a magnifying glass is used to inspect for cracks,,
but who would remove it then put back on- its about the cheapest part in the deal!!
Replace its tensioner and roller/idler pullies too
Old Dec 10, 2011 | 02:08 PM
skilzz's Avatar
Do not take your engine apart!!!
change the crank pulley first. also called a crank dampner.
there is a ring inside these that get loose when they start failing and will give you the most annoying knocking ever. and its sooo hard to pin point
Old Dec 11, 2011 | 12:35 AM
sammy95's Avatar
^ The harmonic balancer is another name for it.
Usually causes vibrations, more than knocking. I've seen one where the rubber between the belt part and the center disintegrated easy hour of labor I think.
If it was the balancer you should notice a difference in noise level with the serpentine belt off or on.
It's worth a shot to try.
Old Dec 11, 2011 | 11:13 AM
99a32tl's Avatar
7th Gear
havent tried seafoam in the oil, i am assuming that once you hear a knock damage is already done and im afraid that if i drive it more and there is bearing damage it might spin a bearing
if i put a can of seafoam in the crankcase, how many miles would i have to put on for it to actually do something??
i put the NGK v-power plugs in it and the old ones looked just fine, normal wear, mind you there was a multiple cyl misfire when i got it and it was a dead coil on cyl #2. not sure how long it was driven like this for either
havent done a compression check yet
it is not a salvage or rebuilt title, but the previous owner did use it as a winter car so i assume that it sat for a few months in the summer.
it was the auto tensionner that was seized which is for the serp belt (alt and a/c) had to cut the belt off to take the tensionner out. i started the vehicle with the belt off and still heard the knock. it did still have the ps belt on though.... not sure about the harmonic suggestion
Old Dec 11, 2011 | 06:44 PM
99a32tl's Avatar
7th Gear
alright 01tl4tl,
so i went ahead and poured half a can of seafoam in the crankcase and then also performed the seafoam through the intake (a full can).
lots of smoke came out, i couldnt believe it
i then took it for a spirited drive on the hwy and side roads keeping it above 4000rpm
i then changed the oil and filter and the tick is still present
the guys that were talking about the balancer falling apart and knocking, would you think removing the serp and the ps belt make a difference??
i really dont want to drop the oil pan...lol
thanks
Mike
Old Dec 11, 2011 | 10:32 PM
sammy95's Avatar
Removing the belt and rechecking, eliminates anything driven by the crank pulley. A/C compressor, p/s pump, alternator...
If the crank pulley is suspect you should see bits of rubber coming loose between the two parts of the crank pulley. Also the frequency of the noise should change if the problem is with the pulley.
Old Dec 12, 2011 | 11:41 AM
fsttyms1's Avatar
Which we dont have.
People are getting their crank pulleys confused with the harmonic dampers found on some domestic V6 & V8 engines. "Harmonic Balancer" is a term used loosely in the automotive industry. Technically, this type of device does not exist. The "balancer" part comes from engines that are externally balanced and have a counterweight cast into the damper. None of the applications we offer use a counterweight as part of the pulley, as these engines are all internally balanced.
The pulleys on most of the new import and smaller domestic engines have an elastomer (rubber ring) incorporated into the pulley making them look similar to a harmonic damper. The elastomer in the OEM pulley serves as an isolator, which is there to suppress noise from the engine accessories; the A/C compressor, P/S pump, and alternator. This is what the manufacturers call NVH (Noise Vibration & Harshness) when referring to noticeable noise and vibration in the passenger compartment.
Old Dec 12, 2011 | 01:30 PM
sammy95's Avatar
I stand corrected. Thank you sir. Crank pulley is the name.
If this elastomer came apart, it could cause noise if all the rubber came out right?
MrHeeltoe
20
Feb 23, 2023 01:54 PM
IBankMouse
Jun 13, 2020 12:53 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
STL TL-S
Sep 23, 2015 08:52 PM
