blinking green light????
Old Dec 26, 2001 | 09:23 PM
TLover8888's Avatar
what is the blinking green light with a diagram of a key on it in the instrument panel of the dash? it blinks even after i turn the car off and pull the key out of hte ignition.
Old Dec 26, 2001 | 09:35 PM
TUFF GONG's Avatar
Open the glove box and you will find your answer in this little book called a "Owners manual"
Hehe, I believe it regards the Immobolizer. (I haven't read about it myself )
Old Dec 26, 2001 | 09:38 PM
pianoman41's Avatar
Re: blinking green light????
Check your manual. It's the icon for the theft immobilizer system. Once you pull the key out, it's telling you it's activated and won't start the car unless the chip in the key activates the ignition system. I believe if you stick a non-chipped key into the ignition it will flash as well.
Old Dec 26, 2001 | 09:41 PM
TLover8888's Avatar
damn, no need for sarcasm :p
Old Dec 26, 2001 | 09:42 PM
TLover8888's Avatar
Re: Re: blinking green light????
thank you pianoman41...
Old Dec 27, 2001 | 11:19 AM
doopstr's Avatar
It's saying "hey you dope, don't forget your key"
Old Aug 25, 2011 | 10:21 AM
mendozad's Avatar
HELP! Immobilizer green light flashing!
Okay guys, I need to get some info if you can help. I have an 2000 Acura TL with 280,000 and going strong. I was going drown the highway and a green light started flashing on the dash. I had no idea what that was so I immediately stopped to get the owners manual to see what it was. I turned the car off to check and it said it was the immobilizer which reads the chip in the key. It says it comes on when the immobilizer cannot read the key. I tried to then start the car and it would NOT start. It almost sounded like the battery was low - had clicking sounds - would not turn then the green light started flashing again. I live in Texas and its been 105 degrees since late May. I looked on-line and another mechanic (that you have to pay) had an answer from someone that had the same problem as me and he said it was not her key - it was a dead battery. Is this true? Can your battery connection be lose and cause the immobizer not to read the key and cause the light to flash? Any help would be great. I am asking my boyfriend to take the battery to get it checked out. If it happens to be the battery how do you get the key programmed again or will it just work once a new battery is put in? THANKS
Old Aug 25, 2011 | 11:22 AM
my.daily'tl''s Avatar
Always Working In
Your key is tied to the car's computer. Have the battery and the rest of the electrical system tested at your local parts store. Never heard of a low battery causing this problem.
Old Aug 25, 2011 | 11:43 AM
01tl4tl's Avatar
makes total sense--extreme underhood temps will kill a battery
low voltage starts causing false CEL type lights- immobilizer/ignition/ecu gets wrong voltage, and when you shut it down it doesnt believe its got the right key trying to start it
batt, maybe even alternator- sometimes one takes out the other,
parts stores run a full test for free!!
If there is a Batteries Plus store near you (ck online or phone book)- they have awesome service and great batt, they even fully charge each new battery on a giant Battery Maintainer machine- so its ready to go 100% for you.
Most places have units sitting on shelf for months- self draining
Ask for a `Blemished` battery if they have one in your size, I saved $40, down from 85- for a batt with mounting tab we dont use, was broken. batt works perfect otherwise!
many are finding our cables have lived their lifespan and its time for them too
If you had crud buildup on batt terminals= those cables are eaten away inside
Old Aug 25, 2011 | 11:48 AM
01tl4tl's Avatar
99s had major prob with ignition switch backside- the electrical part
later years suffer same prob to lesser extent- an 00 may have it
symptoms are engine shuts off and back on, dash lights come on, may occur more on corners.
Are there many keys on your ring?= weight
does moving the key in ignition do anything?
Most DIY replace the part, $50
one ziner took it apart and cleaned years of crud- it worked fine afterwards
Old Aug 25, 2011 | 04:49 PM
Karanx7's Avatar
Unregistered Member
All I can say is that the key has no battery inside of it for the chip.
Old Aug 25, 2011 | 05:34 PM
01tl4tl's Avatar
its some sort of interregator system from the car to key,
you can buy a module for aftermaket `remote start` system- fooling it to think a real key is in the car while you are in the house
rockyboy
Aug 4, 2024 10:35 AM
BigJilm
Sep 21, 2015 08:32 PM
PortlandRL
Sep 14, 2015 12:01 PM
HeloDown
Sep 8, 2015 06:51 PM
