blake light please help????????????????????????????????????
Old Sep 22, 2004 | 07:31 PM
figueroa1357's Avatar
when my car is cold i I begin to drive the brake light comes on only till it warms up any else have this prob, btw i tried using there pressing and releasing parking brake and it still stays on. THAANKS in ADVANCE.
Old Sep 22, 2004 | 07:47 PM
yield2s's Avatar
first make sure the fluid level is good, then go from there
Old Sep 22, 2004 | 09:14 PM
This happened to me when I lived in a cold place... just top up the brake fluid and you will be fine.
Old Sep 23, 2004 | 11:24 AM
Bareback's Avatar
TL = Tranny Lubrication
I had the same issue, the brake fluid level was fine, the light would come on due to water on the sensor in the wheel well. I Removed my wheels, and cleaned the inside and dried out the lines and taped the sensors, no more issues...
Seem to only happen when it rained a lot, especially after the 2 hurricanes we had.
If this doesn't work for you I would take it in and have it checked out.
Old Sep 23, 2004 | 11:33 AM
orcaatk's Avatar
This happened to me and it turned out to be the cap on the master cylinder. There's a sensor/switch in the cap that has a tendency to go belly after a cold snap. The dealer fixed it under warranty.
mada51589
Jan 9, 2025 04:40 PM
Dec 7, 2020 05:39 PM
sockr1
Oct 1, 2015 01:31 AM
wusty23jd
Sep 24, 2015 11:41 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
