BIG OPPPs...need help from the pros FAST!
Old Apr 9, 2005 | 09:43 AM
etxxz's Avatar
@ slide or die @
Exclamation BIG OPPPs...need help from the pros FAST!
I was just retightening my headers's bolts because my resonance was getting a bit outa hand...and the central bolt on the front side BROKE!!
there are 5bolts going | - - * - - | well the "*" one broke.
Someone let me know what to do...how to repair...dealership $$? i dunt care, i gotta get this fixed...i'm gonna turn on the car see if there's leakage
hope to hear very soon from you,
ETXX
Old Apr 9, 2005 | 10:16 AM
etxxz's Avatar
@ slide or die @
ok there's no leakage...everything seems to be solid...i'm worried guys
BTW, when i meant bolt ^^ it means the SCREW broke...not the nut...the SCREW coming out of the block...o man!
:help:
Old Apr 9, 2005 | 10:54 AM
Titand19's Avatar
East Coast Boost.!
ok dude relax it's ok. Is it the front or rear?
Either way you need to pull it out. If it's not that tight see if you can grab it with visegrips and twist it out. If that doesn't work. You need to use a stud remover, or if you drill a hole in it, you can use, I forget what it's called looks like a cone drill bit. When drilling though, you need to use left handed drill bits. A down side for this app. it will prob require a right angle drill. Good luck.
Old Apr 9, 2005 | 11:11 AM
fsttyms1's Avatar
i agree. you will have to remove the header on that side then remove teh remaining stud with a pliers or visegrips. then reinstall every thing and get a new bolt
Old Apr 9, 2005 | 04:18 PM
etxxz's Avatar
@ slide or die @
oh, okay...sounds a lot simpler...i thought i had to get the remainder plasma cutted out and weld back on a new one
Its the front header so that makes the job a lot easier and if anything i'll just remove the radiators/fans to make space for the drill bit if the pliers or vicegrip don't work
I'll have to wait till my corolla is done so i can do this because i dont have 4-5hours to do this job...not to mention i need my friend's because of a slight fitment issue.
the dealer will find the stud...lets hope they're cheap!
THANKS YOU TWO!!!
Old Apr 10, 2005 | 12:12 PM
Mr Hyde's Avatar
yup do what they said, and MOST importantly, get a torque wrench for the removal, and reinstall. The Header studs are alot softer than most people think.
Old Apr 10, 2005 | 02:57 PM
etxxz's Avatar
@ slide or die @
no need for a torque wrench now since i now know how hard i can go...i'd rather spend those $20 in something more usefull...like a 12pak while i do the work with my friends
i'll post some pics of the work so i can show off my manly bugg ruggedness!!
Old Apr 10, 2005 | 03:30 PM
fsttyms1's Avatar
yup. header bolts (and head bolts, atleas be inspected) should be replaced after removal. due to heat and stress on them they stretch and are more prone to breakage
emailnatec
29
Sep 28, 2018 04:27 PM
Jinkazetsukai
Nov 21, 2015 05:28 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
Froid
Sep 27, 2015 06:16 PM
AcuraKidd
Sep 25, 2015 11:18 PM
