Big brake kit
Big brake kit
Does any one have pictures of any big brake kit on a stock 2002 TLs rims. I want to upgrade my brakes with out changing the rims, I need to save money for the SC kit some day.
i dont know if you can put the factory rims on with a big brake kit on
That looks very nice, Can you please answer 2 questions for me.
1. Is that stock TLs rims( I guess 2002 and 2003 are the same size) ?
2. Is that just 1 5mm spacer or did you have to change something.
Thanx
Thanx
sorry for this dump question what do you mean nuts on both side.Did you get the spacers from HR directly? How is the brakes,can you stop on a dime now?
It means I am still using the factory studs and lock nuts with the spacer on, brake feel much better than stock plus you got a stiffer padel feel also, one thing I can't for sure about stop on a dime; because I still trying to break in the pads but I did some sharp braking during heavy traffic days before, I was like :wow:
you know what I mean.
What do you mean by "big brake kit? A 12in to 12.4 inch should fit with the mentioned spacers to clear the caliper. A 13in kit needs an 18in wheel. What is the size of the Rotora pictured above? Whatever you are contemplating, spoke clearance of the caliper is critical.
Might want to check this thread also.
http://www.acura-cl.com/forums/showt...hreadid=121576
nuldabz
09-03-2015 05:49 PM
