"Beep" on Entry
Old Sep 3, 2002 | 05:33 PM
rickandcheryl's Avatar
5th Gear
"Beep" on Entry
Anyone know what causes a beeping when you open the door and get in the car? My 2003 TL-p will sometimes give a short beep, a short pause, then two more short beeps when you open the door and get in. It does not do this all the time, only intermittently. Anyone know what this is or what is causing it??? Thanks, Rick
Old Sep 3, 2002 | 05:37 PM
Alexxx's Avatar
You are pressing something on the remote and its causing the your seat to adjust from positoin "1" to position "2" or vise-versa. If you look on the back of your remotes you will see that it shows two different numbers (1 and 2) for two different drivers. The manual covers that more in detail.
Old Sep 3, 2002 | 07:10 PM
SilverUA5's Avatar
Re: "Beep" on Entry
Sounds like your power seat memory settings. Did you adjust the seats before you arm the car?
Old Sep 3, 2002 | 09:11 PM
Ajay_RENAMED's Avatar
It's a bomb, RUN!!!!!!!!!!!!!!!!!!!!1
Old Sep 3, 2002 | 10:59 PM
TLS RULZ's Avatar
YEAH !!!! Its setting the Timer for a 10 sec countdown !!!!!
Old Sep 3, 2002 | 11:35 PM
Eternal TL2k3's Avatar
wouldnt reading thru the manual have answered that question? then again there have been times that ive posted stuff on here cuz im too lazy to go to the manual... so ill take it back
Old Sep 4, 2002 | 03:12 AM
AKRY's Avatar
MB-Fanatic w/TL-S
You must have adjust the seat during the time when you were driving.... when you approach your car and open up the door... the first beep means that the seat is going to its preset position(either Memory 1 or Memory 2 depends on which Key Fob you used)... once it's in the preset position, the 2 beep sound confirms that it's now at your preset position....
it's normal...
Andy Kuo
MrHeeltoe
20
Feb 23, 2023 01:54 PM
Jul 16, 2017 07:33 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
