BAYA AV6 swap, Jetted ATF fill cap
Old 03-30-2024, 07:46 PM
cygnusx-1's Avatar
Hello,
Been lurking for a while around here, currently doing a trans swap on an 02 TL. Brought a reman BAYA and noticed the ATF fill plug on top of the trans has a hole in it, I presume for a jet kit. My TL trans never had the jet kit installed, as the ATF plug is solid, and green. I was curious if the jet kit was necessary/advised for an 06 BAYA trans, or if I can forgo it and just used the old ATF plug.
If it's necessary, where could I source a kit? Does anyone have any information regarding the plumbing of said kit as well? Any help would be much apricated, as I have no desire to have another transmission fail.
Old 03-30-2024, 09:42 PM
Received 1,773 Likes on 1,427 Posts
Originally Posted by cygnusx-1
Hello,
From what I understand, looking at the yellow highlighted AV6 install instructions below, it is stating to eliminate the oil jet kit altogether?
Even if you wanted to add one, for extra protection, it appears #41 Pipe A (ATF) is discontinued & no longer available.
It looks to have an extra 'port' (red arrow) when compared to #12.
5AT ATF Warmer - Speed Sensor - 2003 Acura TL 4 Door TYPE-S KA 5AT (acurapartswarehouse.com)
Old 03-31-2024, 02:38 AM
cygnusx-1's Avatar
Thanks for the quick reply. Do you have a source for pic related? I want to make sure that I'm not missing anything else before I put the trans in, looks like a pretty good writeup. I figured the BAYA would be ok without the jet kit, just got puzzled when I saw the ATF plug.
furious stylez
12-24-2022 10:38 PM
outlawspeeder
02-14-2015 03:52 PM
yahelou
01-19-2014 09:26 AM
myblack04tl
03-22-2010 08:59 AM
veldacls
2G CL Transmission Recall Q & A
11-11-2004 07:45 PM
Quick Reply: BAYA AV6 swap, Jetted ATF fill cap
