BAYA AV6 swap, Jetted ATF fill cap
Hello,
Been lurking for a while around here, currently doing a trans swap on an 02 TL. Brought a reman BAYA and noticed the ATF fill plug on top of the trans has a hole in it, I presume for a jet kit. My TL trans never had the jet kit installed, as the ATF plug is solid, and green. I was curious if the jet kit was necessary/advised for an 06 BAYA trans, or if I can forgo it and just used the old ATF plug.
If it's necessary, where could I source a kit? Does anyone have any information regarding the plumbing of said kit as well? Any help would be much apricated, as I have no desire to have another transmission fail.
Hello,
Even if you wanted to add one, for extra protection, it appears #41 Pipe A (ATF) is discontinued & no longer available.
It looks to have an extra 'port' (red arrow) when compared to #12.
5AT ATF Warmer - Speed Sensor - 2003 Acura TL 4 Door TYPE-S KA 5AT (acurapartswarehouse.com)
From what I understand, looking at the yellow highlighted AV6 install instructions below, it is stating to eliminate the oil jet kit altogether?
furious stylez
12-24-2022 10:38 PM
yahelou
01-19-2014 09:26 AM
