Battery for 2000 TL
Battery for 2000 TL
Hello to everyone. I have been a member on this side for less then 2 month and really enjoy it. I like you guys, you are very helpfull. And once again I need your advice.
I am going to replace my original 2000 TL Delco battery. I've done some reading here about Optima redtop and Delco batteries.
Guys, what battery would you recommend me to buy (if you may give me a price range that would be great).
Thank you all in advance.
if you need it for nothing more than starting your car a sears diehard or like battery will suffice. if you dont mind spending the money then the optima red top is your best bet
many car audio shops, sears
Originally Posted by Cooldmitriy
Thank you guys. Are there any diffirent flavors of RedTop batteries? What about OEM Delco?
Hi fsttyms1,
I checked out SEARS's web site and found 8 diffirent Red tops available for sale :-) What model do I need?
I also went to Optima web site, picked ACURA from the list and search came back with no matched.Not sure why.
75/35 red
yup, make sure you get the cover. you will need it to sit on so that the battery sits high enough for the tiedown
May I utilize original cover that came with my Delco battery or it will not fit?
it should come with it, its just al small (about)1" thick piece of plastic that the battery sits on to raise it up highenough
Yup!
fsttyms1, I went to Pep Boys and they checked their database for Optima batteries, but could not find anything for Acura 2000. I told them that 75/35 should fit, but they said that if Optima does not offer anything for Acura, then there's the reason for that.
I found one 75/35 with a plastic cover on the shelf. My question, do I put that cover on the bottom or the top of the battery?
battery reemoval
Very basic question: How do you remove the cover from the battery on a 2003 TL? I see no bolts just something that looks like a washer. I just want to check the posts for corrosion but can't get to the battery. Thanks
TL = Tranny Lubrication
Originally Posted by 03CoupeV6
Well if it raises the battery up, I'm going to take that to mean you put it on the bottom.
If you don't feel like spending $110 on a Optima battery, pick up a cheap $40 one at Costco, they are made by Johnson Controls Inc. They not only make the Optimas, but they make Diehards, and the Honda OEM batteries that were in our car from the factory, as well as many many others....you cannot go wrong, a 3 year full replacement warranty at Costco as well.
MetalGearTypeS
08-29-2016 08:28 PM
