Bad tint job?
Old 05-02-2009, 08:48 PM
Tay119's Avatar
Bad tint job?
So I noticed on my friend's car with tint on his front windows that his tint goes all the way to the top. Mind doesn't, it stops short.
Also, my tint doesn't look perfect at the top of the back window. Not sure if this is a crappy job or just not possible to do.
And of course, now I know the shop is definitely too lazy since they couldn't tint the rear light and didn't ask me either.
Is it worth going back to them and complaining? Or is there anything i can do myself?
Old 05-02-2009, 09:41 PM
Got your mom in
Silva-type-s's Avatar
how long ago did you get it? it usually take a few days to settle
Old 05-02-2009, 10:30 PM
MurdaZ's Avatar
mine doesnt go up all the way either, but the dotmatrix and the 3rd brake light is bad. most will wetsand the matrix to flatten it, then tint over it...give it time to settle then complain
Old 05-02-2009, 11:55 PM
'13 Hyundai Sonata
TLin401's Avatar
My windows is at pretty much the same level that yours is at. I would def complain about the brake light. It takes like 1 minute to take out; all it is is like 2 screws. If you just got it done then the dotmatrix will settle. I got mine redone last week and it finally settled and looks normal.
Old 05-03-2009, 12:29 AM
Tay119's Avatar
i got this done months ago, i wanna say like it october of 08. and my friends accord coupe's tint went all the way, it looked much more pro than what i have. mayve it was cuz they're frameless doors but idk.
Old 05-03-2009, 12:38 AM
'13 Hyundai Sonata
TLin401's Avatar
Mine are frameless and they go to your level. I would go back and have the rear window redone
Old 05-03-2009, 12:48 AM
Tay119's Avatar
then i'll stop being concerned about my doors. they just look kinda dumb IMO. but ya, i think i'll stop by the tint place soon and ask them about it, maybe redo it
Old 05-03-2009, 04:40 AM
2G wanting 3G
9932's Avatar
every tint job i've seen has that 1/4in missing on the front windows.
the back will look like that because of the dots, only fix would have been to put a strip of solid vinyl before the tint job
cutting around rear break light is BS, they shouldve taken off that sub woffer cover (does it look like that around that plastic piece at the top of the window too?
Old 05-03-2009, 10:23 AM
Keep It Simple in
SLushhYYY's Avatar
My tint goes to the very top of the windows............
Old 05-03-2009, 10:49 AM
Tay119's Avatar
it's on my rears that it's missing but i doubt it matters that it's rear instead of front. and what plastic piece at the top of the window? you can see the whole back window in the 3rd pic.
Old 05-03-2009, 05:11 PM
Odrum11's Avatar
I always thought it was Illegal to tint over the break light unless you specifically ask.. Just like how in some places it's illegal to get under whatever percent tint (depending on region) but if you ask they'll still do it. Then again, that's here in Toronto though.
The back window is pretty bad though. Did they give you some sort of warranty?
Old 05-03-2009, 05:26 PM
Flipster23's Avatar
Received 2,334 Likes on 1,962 Posts
My fronts go all the way up..the dot matrix they need to lay vinyl on the back and do it that way. mine looks like your right now because who ever had it b4 me went to a shop that didnt do the dot matrix
Old 05-03-2009, 05:29 PM
Oh Hullow
03bl AC k CL's Avatar
i asked ahead of time to tint over my brake light since i have a spoiler... and my windows go up to the top just about there is a very small area untinted at the top... my dot matrix is similar but not as bad. go back and complain if you arent happy. dont settle for something that doesnt satisfy you. you are a paying customer after all.
Old 05-03-2009, 05:55 PM
Tay119's Avatar
so i have some sort of lifetime warranty agaisnt liek fading or cracking tint but idk if theres anything about crappy installation. woudd it look bad to just have a little piece cut and put over the brake light? is the dot matrix even fixable without doing the back window again?
Old 05-03-2009, 06:00 PM
Flipster23's Avatar
Think you gotta do the whole rear window over again kuz the need to lay the vinyl down b4 they tint. not to sure
Old 05-03-2009, 06:49 PM
MurdaZ's Avatar
to do the 3rd brake light, get them to do it all over again, cant to patch work, will show once dried
Old 05-03-2009, 08:53 PM
Tay119's Avatar
i'll try and get to the tint shop next weekend and see what they'll do or how much it will cost. i'll update then
Old 05-04-2009, 11:28 AM
NSXNEXT's Avatar
Received 1,080 Likes on 661 Posts
It's a bitch to remove the tint from the back window because of the defroster. You should have gotten everything writing before the work was started. It's your word against his now.
Old 05-04-2009, 05:58 PM
The Dumb One
Rockstar21's Avatar
good tint shops dont tint to the top of the window.. they know that if its too close to the edge.. that "eventually" it will start to fold back from rubbing the seals at the top of the door... so a little space is normal.. some space more or less..
and unless you take the 3rd brake light out, i dont think its a tint shops job to remove interior pieces unless you ask ahead of time.
the cut around mine and i cant blame them. but next time i go i will be sure to remove it so they can tint all the way down...
Old 05-04-2009, 06:21 PM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
Ive NEVER had a professional tint job not go to the top of the window. Ive also never had it peel back. There is almost 9 years and 320+k on my tint and its still in great shape there. They can tint behind the brake light without removing it, cutting around it is a sign of being lazy. A good shop will take the time to do it right and not cut corners.
Old 05-04-2009, 06:32 PM
Avant Garde Wheels
jjashaa's Avatar
Old 05-04-2009, 08:07 PM
Tay119's Avatar
but do you think it's worth going back? do you think they'll redo it?
Old 05-04-2009, 09:27 PM
'13 Hyundai Sonata
TLin401's Avatar
How long was the warranty? If you have it or not it is worth going back
Old 05-04-2009, 09:33 PM
Flipster23's Avatar
thats not true my tint place is excellent and they go to the top of the window i never ever had a problem with the tint folding back.
OP did you go to a joe blow tint shop. They give you a reciept with anything saying warrant yor anything.
My tint shop is lifetime warranty that wouldnt do a crappy job like that though. Even if i move out of the state any tint place that sells that tint will replace it for free. They maybe expensive but its hella worth it
Old 05-04-2009, 09:39 PM
Tay119's Avatar
well i was actually recommnded by a friend b/c he got his tails tinted there. but i have receipt... it doesn't say anything about warranty. i know they told me it was lifetime. but that doesnt cover crappy install, u kno?
Old 05-04-2009, 09:43 PM
Flipster23's Avatar
Well they didnt have pics of there cars they done before. I would go back in there and see what the say be like hey look at my dot matrix can we work something out with you guys putting the vinyl in and tell them your brake light looks like shit. Just say hey look at this its looks horibble can we do something about this
Thing with my shop is i give them hella business and if they ever did eff up my car and wouldnt fix it ill tell no one to go there anymore LOL
Old 05-04-2009, 10:18 PM
Tay119's Avatar
thanks for the advice. i'll try and get in there this weekend
Old 05-04-2009, 10:49 PM
03 SSM
SLCTL's Avatar
Im too lazy to read all 2 pages but the top is because the shops tint doesnt cover the entire back window and/or due to the stock "tint" on the rear window they use more adhesive otherwise it would be see through. The adhesive darkens the tint.
Old 05-05-2009, 10:36 AM
The Dumb One
Rockstar21's Avatar
every place is different i suppose... they leave an 1/8th of an inch on purpose the place i use.. its actually more time consuming because they freehand the cut instead of using thetop of the glass or the rubber seal at the top of the door. maybe yours hasnt peeled but i've seen tint jobs peel at the top b/c of this very thing. cars and windows are all different. but i love my shop and they do this purposely and i love their work
grass is green...
Old 05-06-2009, 09:45 PM
S E L L
Gfaze's Avatar
My tint goes all the way up to the top. I've never had a problem. Both of my sisters' cars, both of my dad's trucks, and several of my friends' cars have all gotten done at the same place. None of them have any complaints and they're all all the way to the top. The windows with the dot matrix pattern look good too.
To the OP: The shop you took your car to did a half ass job. I'd take it back and have them redo that back window. It looks awful.
Old 05-06-2009, 09:58 PM
Low is a Lifestyle.
CGP CL9's Avatar
yeah thats not a good tint job. i paid 320 for my tint job at Lorenzo Custom Window Tinting. They used Madico Char-cool tints and they did the best job I've ever seen. Super-Professional, all of the tints go up to the top of the window. They can do moleskine if you ask + pay. You can watch them do the whole thing also. The tint came with a lifetime warranty also against any scratches, peeling, or fading. you should ask the place to re-do yours.
Old 05-06-2009, 10:33 PM
wham bam thank you ma'am
Rajca's Avatar
i went to logan square detailing and got all my windows 5% (not windshield) for $120 with life time warranty. tint goes all the way up and my third brake light is also tinted. im gonna go back their in a month or so to get my cl-s6 tinted. they do a great job. pm me if u need more info and who to get the job done
Old 05-06-2009, 10:36 PM
Rajca's Avatar
sad to tell u bit i over paid . as good as the tint is, theirs nothing special about it that no other tint place can do. as long as they use good tint and a good job i would not pay more than $200.
Old 05-06-2009, 11:09 PM
S E L L
Gfaze's Avatar
!!! You got robbed!
Old 05-07-2009, 10:13 AM
WILL PLAY POOL FOR CASH
Black-Balled's Avatar
i got this done months ago, i wanna say like it october of 08...
I would say that it doesn't look too good for you...on multiple fronts.
Thanks for sharing tho- I want tint and it is helpful to know what to be prepared to address on the front end.
Old 05-07-2009, 12:20 PM
JCharged's Avatar
Yikes! I have to get mine redone soon.
Old 05-07-2009, 10:13 PM
Tay119's Avatar
just talked to the owner. i'm gonna gead in there on saturday and see what i can get done.
Old 05-08-2009, 11:44 PM
parvo99's Avatar
If the shop doesn't do anything for you, you can cut the tint just below the dot matrix area, and remove it, then put on black vinyl or paint, or just leave it untinted.
Old 05-16-2009, 11:40 AM
Tay119's Avatar
so finally got into the tint place today. guy says he warned me before he even did the job that the dotmatrix would occur. called silvering. apparently. and regarding the brake light, he says its "30 to 45 min of labor to take out the seats and the back deck". if i take i take it out myself then he woudl have tinted it. seems like he's just lazy
Old 05-16-2009, 11:48 AM
jbracefan1977's Avatar
that's good to hear. maybe he though you would not complain. hehehe.. congrats.
Quick Reply: Bad tint job?
